Hardware Abit IX38 QuadGT
Discussion in 'Article Discussion' started by Tim S, 6 Dec 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    I expected more out of Abit than a pretty board. What went wrong? :blah:
    With the BIOS holding back memory performance that much, wouldn't it be a rather mediocre, rather than awesome, one?
  3. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    The usual thorough Bit-tech review. :)
    Can you say which BIOS version that you tested with?
    Obviously it's early days in BIOS development for this board & improvements are expected over time.
    Your experience with Vcore is interesting as it goes against what most others have been reporting in places like XS etc. - there people are reporting only ~0.04V Vdroop even with a quad which is obviously significantly different from your results.
    I wonder if that's due to a different BIOS?
    & there are certainly some people who are looking at buying the QuadGT specifically because it has a x4 slot for a RAID card etc.
    At the end of the day it's a design choice & whether it's right or wrong for you is upto you to decide.
    Oh & the bundle appears to have been a cock-up - there are supposed to be wire fan brackets for attaching a small fan to the nb included & yes, apparently somebody forgot to spec. the usual abit combined USB & firewire PCI slot plate in the BOM :rolleyes:
    I totally agree about P35 still being a very strong competitor if you don't need the 2nd X16 slot to run Crossfire which is why I'm sticking with my IP35 Pro.
  4. Tim S
    Tim S OG
    8 Nov 2001
    Richard listed BIOS 11 on the test setup page, which is the latest available on Abit's site. I'm guessing there will be more updates in the long run that will improve performance over time... I don't personally think it's a bad board, but it's one that you're only likely to be interested in if you want CrossFire.
  5. BUFF
    25 Mar 2005
    Must have missed that, they're already on 12beta3 so that's probably the difference then.
    I totally agree about Crossfire being the only reason for going X38 & probably X48 too.
  6. Guest-16
    Guest-16 Guest
    Quite likely a different BIOS, or perhaps the reporting of it? What are they using? Or because I was using a 45nm CPU which has a different power requirement. Got any links? :)
    I totally agree that if it has the features you want, it's a great board, but when I invest in something I expect it to perform at least a little better than a previous generation product. I don't like it being at the sacrifice of a PCI-Express GbE though.
  7. BUFF
    25 Mar 2005
    http://www.xtremesystems.org/forums/showthread.php?t=165004
    http://www.clunk.org.uk/forums/reviews/861-abit-ix38-quad-gt-living-review-ii.html
    Doesn't X38 pretty much fall foul of that in general though?
    Other than the 2nd PCI-E x16 slot there is no compelling reason for anybody to go with it over P35 as far as I can see.
    Personally the PCI LAN doesn't bother me as it's still faster than any single HDD can deal with & it's 10s of time faster than domestic Broadband.
    Mind you the x4 slot doesn't bother me either (unless perhaps for a physics card if that proves to be genuinely useful).
  8. Guest-16
    Guest-16 Guest
    It's not faster than hard drive. 100Mbit = 8MByte per sec and "PCI" Gigabit is a fair bit slower than PCIe from what I've read. It's better for LAN gaming too - as long as you have a good Gigabit switch to connect to. The Abit doesn't offer a teaming function everyone else does either, only having a single LAN.
    It is about a million times faster than broadband, but like you say, how many people use an x4 either.
    The two x16 Gen-2 are actually worth having now because of the price:performance of HD38s, but if you don't care about that then it's cheaper P35 all the way.
  9. rito
    rito What's a Dremel?
    19 Sep 2007
    why dont you do some Amd boards for a change?
  10. Silver Shamrock
    Silver Shamrock What's a Dremel?
    19 Sep 2005
    Nice review. If it was a third less in price it would be worth having but it's just too expensive for what it is. I was hoping for much more. A step back from abit. Shame.
  11. Tim S
    Tim S OG
    8 Nov 2001
    Our last motherboard review was an AMD board and there are more in the pipe, but they don't just happen overnight.
  12. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
    Is that because poor old Rich tends to do alot/all of them :p...nice review though.
    There is one gripe, there was a mention of the inability to use the sata clips on asus boards, now maybe i've been silly and used them but all six on my p5n32-e sli have the clips mention and the onbaord ports and all at 90 degrees to the board, just like on the abit reviewed.
    peace
    fatman
  13. Guest-16
    Guest-16 Guest
    Using the Asus 90 degree SATA sockets you have to force in so it bends the plastic out - there are no little gaps like the Abit 90 degree SATA connectors. :)
    I do have another AMD board in the pipe but it's kinda hard when we don't have a Phenom to use long term :(
  14. Supershanks
    Supershanks What's a Dremel?
    14 Mar 2005
    Great review Richard , many points I agree with. Like you I was surprised at the sparseness of the package. I'm not sure about yours but the box / mobo tray is also too big by about 2cm, leaving a mobo that slides up & down the box, which isn't to impressive.
    I could see that this had occured by the scuffs on the tray:-
    The other thing is the lack of fan retension clips for the NB & PWM, despite being shown in the manual.
    I'm running with a Q6600 Go and started off running with a lot of vcore, more than i needed on the Gigabyte X38 Dq6. However i found that tweaking vtt & Gtlref, meant that i could lower vcore, this also added to stability. I've run various >12Hr prime stable settings now. They are detailed here Abit IX38 Quad GT - Living Reviewhad II In most cases this board has out performed the Gigavyte x38 Dq6. so personally i'd give it a little more in the Ocing scorre. AS usual we are waiting for a bios which will enable us to run the 1:1.25 strap which is currently unstable (using Bios 12.B02)
    luck:)
  15. Guest-16
    Guest-16 Guest
    To be honest, I don't have time to go into that much detail. I played with the VTT and GTLRef but we hit our CPU limit, again, at 505. The box fitted the board perfectly though :confused:
    It's good to know there's another resource out there with details, as well as a beta community still. :thumb:
  16. Supershanks
    14 Mar 2005
    No I appreciate that :thumb:
    Cheers:D
  17. BUFF
    25 Mar 2005
    It's about 735Mb/s which is 91MB/s - even a Raptor won't do that for continuous transfer & most other HDDs will be ~50-60MB/s.
    daft question - assuming that you have PCI-E Gigabit LAN & a Gigabit switch, how does teaming help you as the switch surely is the limiting factor i.e. you can't get 2 pints into a 1 pint glass?
  18. TheCherub
    TheCherub Minimodder
    16 Sep 2007
    From a layout point of view, that is possibly the best thought out board I have ever come across. It does seem let down in other areas, but definitely not layout.
  19. zoom314
    zoom314 Minimodder
    10 Jun 2003
  20. Tim S
    Tim S OG
    8 Nov 2001
    Abit's layouts are always awesome IMHO and this is no exception! :rock:
Tags: Add Tags
