About to buy the following system. Can anyone see any problems. Dont intend changing any components if I dont have to, just want to know if there are any glaring problems: CPU: core i5 750 Motherboard: Gigabyte GA-P55M-UD2 PSU: OCZ ModXStream Pro 500W Optical: LG GH22LS50 22x DVD±RW.... http://www.ebuyer.com/product/190671 Case: Xigmatek Utgard HDD: Samsung spinpoint 1TB Already have the below: GPU: HIS 5770 RAM: 4GB 1,600MHz DDR3 If no-one can see any major problems I will get on and order soon. Within my budget. Thanks for looking.
What are you planning to use the computer for and what is your budget? For the current build, make sure its the samsung F3 hdd. The F2 runs at 5400rpm, so is quite a bit slower, and much quieter, and the F1 is just slower than the F3. Also, are you planning to overclock? If you are, add a third party HSF. The titan fenrir is good. If not, the fastest any ram will run is 1,333MHz, so you might as well downgrade the set you've currently got. Its not as if theres a noticeable difference between the two speeds anyway.
Hey mate! That looks fine apart from what others have already mentioned. Having said that, a 600w ModxStream wouldn't go astray in case you want to upgrade the GPU in future!
buy a titan fenrir with that to cool it and so you can overclock the 750 i5 http://www.scan.co.uk/Products/Tita...plus-HDT-CPU-Cooler-(775-1156-1366-K8-AM2-AM3)
