Hello, I live in South Africa and we do not have a wide range of CPU Coolers available, I can get my hands on an AC Freezer Pro 7 Rev.2, but sadly not the recent award winning Thermaltake Frio. I notice that the AC Freezer Pro did not feature in the recent CPU Cooler tests in Custom PC, does that mean that it's fallen out of favour? And is it still a good cooler for 1156? Thanks Paul
I had it cooling my i5 750 and I found it to be a woeful cooler when I started overclocking with idle temps of 56 at 3.8 GHz.. It was alright at stock speeds though.
it is good with a dual core like the i3 or some of the cheaper AMD chips like the 550 basicly good with any sub £100 processor, but it does struggle to cool quad cores
It would be fine for i5/i7 Quad if you are only overclocking to not beyond 3.8GHz and using as low stable vcore as possible...wouldn't recommend you overclocking further than that though. For i3 dual-core, it should be fine for up to 4.0~4.2GHz.
It's nice and quiet (and easy to install atleast on AMD-boards), but the yeah it definitely isn't one of the best performing coolers out there.
i've got one on my i5 750 , the cpu is overclocked to 3.6ghz (1.2v vcore) - prime stressed load temps max out at around 60c - never pushed the cpu past that , so i can't comment how good the cooler would be with a more extreme o/c...
Arctic do have new and improved models coming soon the Freezer 13 and 13 pro. These shuld bring them back to Fenrir and Frio performance
What I fail to understand is Titan Fenrir has gone through a few versions already, yet they seem to fail to realise that lots of people wish that it has support for push/pull configuration. Some people even go and use zipties to add an extra fan for pulling on the existing Titan Fenrirs...ugly as it may
Thanks Phil, I don't think that I will ever clock my i5-750 beyond 3.6Ghz, so the AC Freezer Pro 7 should be good enough, certainly better than the stock Intel cooler which I have at present. The reason for wanting to change is that I've been hitting 90°C on core #3 with prime and whilst gaming - and that's without any overclock, but do bear in mind my ambient temperature is generally a lot higher than the UK! I also have a new case - Antec 600 - hopefully the cooling on that should also assist in keeping temps in the low 80's. Thanks to all the OP for your valuable input. Paul
