accessing a PC connected to my router
Discussion in 'Tech Support' started by scimmy, 30 May 2008.
  1. scimmy
    scimmy Minimodder
    17 May 2005
    Hi People
    We have 2 PCs here, one running Ubuntu (mine) and my Wife's XP home machine. They're both connected to a wired router.
    Is there a way that we can access each others machines to view files and pictures please?.
    Many thanks
  2. monkeybone
    monkeybone What's a Dremel?
    28 Jan 2005
    Using remote desktop software would work, something like tightVNC or ultraVNC as long as they support both platforms.
    Monkeybone
  3. Daniel114
    Daniel114 What's a Dremel?
    9 Sep 2007
    Do you just mean a network share, i.e. access shared folders? Or as monkeybone suggests are you wanting to actually take control of each others desktop?
  4. scimmy
    scimmy Minimodder
    17 May 2005
    Just to be able to access folders on each others PCs really
  5. culley
    culley What's a Dremel?
    12 Jul 2006
    You need to install samba on the ubuntu computer, its very easy there loads of guides out there.
  6. Glider
    Glider /dev/null
    2 Aug 2005
  7. scimmy
    scimmy Minimodder
    17 May 2005
    Many thanks for all of the help :)
  8. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    i was able to browse windows pc's with ubuntu without adding further apps
    just use the my computer linux thingy, easy
  9. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Same here, viewing the windows data from linux is cake. Haven't gotten the other way working yet, but then I haven't really tried, either.
  10. DougEdey
    5 Jul 2005
    For Ubuntu, just use the file browser to select the folder you would like to share, right click -> share
    It'll pop up Synaptic to install stuff.
    For windows, do the same, except goto control panel -> Networking -> Disable password protected sharing (unless you want it)
