Planning Acrylic perspex sheet flexibility
Discussion in 'Modding' started by Drysofar, 4 Oct 2015.
  1. Drysofar
    Drysofar What's a Dremel?
    5 Nov 2006
    A question guys, how thin a sheet of acrylic at about 480mm by 350mm to bend round at about 410mm radius. Without undue force
    for the front of my Case
    cheers in advance
  2. Cheapskate
    13 May 2007
    You want to bend without heating?
    I'm not sure if they make polycarbonate sheet thinner than 1/8" but a 1/16" sheet would be perfect since it's pretty flexible.
    You could pull this off with 1/8" maybe, if you are sliding it into a groove, but the force will be right on the border of "undue".
  3. Drysofar
    5 Nov 2006
    fits
    For info 2mm plexy bends fine at this curve not much force at all.
    Ok you can't see much cos it's see through. But it is there.
