Guide Acrylic pipebending 101
Discussion in 'Modding' started by B NEGATIVE, 4 May 2013.
  1. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    This thread is a brief how to on bending acrylic pipe and the basic use of a former.
    First up is the basic kit we need.....(Magoo optional)
    We have a heatgun,tube,silicone fuel line that has an OD matches the ID of the tube you wish to bend and a former....the square is for checking the 90 bends on the former.
    So,the former,in this case a 2" wide piece of sheet alu rolled over a deodarant can to get a radius,you can select anything with a diameter of 40mm or over,thick walled tube will need a larger radius to prevent kinks.
    The line is the bend start,this will become clear in a minute
    The beauty of this is that you can form any specific angle you like and bend tube to it.
    For instance: You have 2 ports you wish to join on the same plane,you can form the pathing from the inner measurement between the ports and bend a former to suit. Measure the closest points between the fittings from the actual tube insert point,bend the former so the 2 faces on the 90s match the gap and Bob is indeed your uncle
    The silicone fuel line.
    This needs to be around .5mm smaller that the ID of the tube you are bending
    Normally used for RC cars,chosen for its high melt point and great flexibility.
    The small cut line round the tube is placed at the start of you bend and is the reference point for another way of doing point to point bending.
    Remember the pencil line on the former? Well,put the cut line of the silicone tube on that ref point when doing the bend and you will get consistent bend radius measurement.
    Like this.
    For example: I want to tube 2 ports 150mm away,inlet to inlet on the inner points,I know that a bend will have a measurement of 20mm from that mark in the fuel line to the inner wall of the radius. Knowing that,we can make the first bend using the ref point on the former,insert the tube with the mark 130mm away from the inner wall of first 90,make the bend using the ref point on the former and both inner walls will be 150mm away from each other.
    The bend.
    You cant see the fuel line mark but its ion line with the former ref point,this is the distance you will need to heat up ,around 100mm with the bend start 2/3 its length .
    This creates a very even bend.
    Hold the tube around 70mm above the heat gun on high.
    IMPORTANT: Keep the tube moving,rotate constantly,do not let the heat sit in any one place.
    Soon the tube will not be able to hold its own weight,this is the critical moment,too long and it will create visual anomalies and start to burn.
    Now i dont have pics for the next bit as i only have one pair of hands ...
    When the tube starts sag,quickly transfer to the former,matching the 2 ref points up and slowly 'form' round the radiused section,dont force it,take your time. If it starts to stiffen then re heat as required.
    When you are happy with your bend then let it cool naturally,when cool you can twist the fuel line straight out with no fuss.
    You should be left with this
    I will be adding more on the former when Magoo finds a human lackey to do the pics.
    As always,heatguns are awesome but burn stuff,be careful.
    Fittings and Tube:
    EK & E22 acrylic tubes come in 10mm ID and 12mm OD sizes. Both EK and Bitspower have non-compression fittings for the 10/12mm acrylic tubes.
    EK and Bitspower C47 fittings are double O-Ring fittings.
    Bitspower C48 fittings are skinnier and use a single O-Ring.
    EK & Bitspower fittings grip really tight and you need to ensure you camber the edge of the tubes at an angle else (eg: 45deg), else you will tear your O-Rings when you put in your tubes. It helps to coat the tip of your tube in silicone grease,a thin smear will do,prior to inserting into the fittings.
    You'll need to ensure your tube is seated all the way to the end and past the 2nd O-Ring.
    The “seating depth” of the tube on C47 fittings is 8mm.
    The “seating depth” of the tube on C48 is 4mm.
    The “seating depth” of the tube on EK fittings is 9mm.
    The PrimoChill acrylic tubes comes in
    Inner Diameter: 3/8in.
    Outer Diameter: 1/2in.
    Wall Thickness: 1/16in.. This means that PrimoChill acrylic tubes and fittings are NOT compatible with EK, E22, & Bitspower tubes and fittings.
    ITDiva has done some testing of other former materials and found that Buna N cord has nice properties for this method,it swells slightly when warm and shrinks when cold.
    A nice alternative to the silicone currently used. As always,a former OD of 1mm less then the acrylic ID applies.
    Monsoon have come to the game with a new mandrel set with everything you need with the basic technique shown above but with purpose built mandrels/formers and a new range of fittings with a novel locking technique.
    The Monsoon hardline kit videos:
    http://geno.boxgods.com/Hardline_Premium_Fittings.mp4
    http://geno.boxgods.com/Hardline_Tools_Heatgun_Kit.mp4
    http://geno.boxgods.com/Hardline_Tools_mandrels_and_Measure.mp4
    http://geno.boxgods.com/Hardline_Tools_mandrels_and_Measure_2.mp4
    http://geno.boxgods.com/Hardline_Cutting_Kit.mp4
    This OP will be updated with a pictorial of it in use when my kit arrives.
    Monsoon Kit.
    The bend quality is excellent! A slight pulling motion round the mandrel makes the bend flow very well.
    chris182 likes this.
  2. Boorach
    Boorach Minimodder
    16 Feb 2013
    Nice guide. Thanks for posting it.
  3. chris182
    chris182 What's a Dremel?
    6 May 2011
    Thinking of trying my hand at acrylic pipes, so a great guide. Thanks! Have some rep! :D
  4. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Great guide man!
  5. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    They really do need to sticky this... It's helped me out massivley!
  6. SystemiK
    SystemiK What's a Dremel?
    2 Aug 2013
    Thank you so much for posting this guide! I'm going to need some large radius bends and had no idea how I was going to pull it off...I think you've saved me from going copper!
  7. B NEGATIVE
    8 Aug 2011
    Fittings and Tube:
    EK & Bitspower fittings grip really tight and you need to ensure you camber the edge of the tubes at an angle else (eg: 45deg), else you will tear your O-Rings when you put in your tubes. It helps to coat the tip of your tube in coolant prior to inserting into the fittings.
  8. B NEGATIVE
    8 Aug 2011
    Right then,I have something new to suggest as a former.
    The way to fine angles as a carpenter is the use of our friend ,the Bevel.
    Most bevels have the 'blade' mounted along the centerline of the tool and also have a rounded end,set your angle and form the tube round the blade and 0 block.
    Much easier and endlessly reuseable.
  9. siliconfanatic
    10 Sep 2012
    By cambering the edge of the tube, do you mean chamfering the outer edge?
  10. B NEGATIVE
    8 Aug 2011
    Yup,you must relieve the sharp edge of the cut tube before insertion
  11. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    Super useful thread needs stickifying. :thumb:
  12. siliconfanatic
    10 Sep 2012
    Hung up the banhammer just a tad too soon, eh?. :p
  13. DarthBeavis
    DarthBeavis What's a Dremel?
    29 Aug 2008
    I have to re do a couple tubes had cracks from moving to and from LANS
  14. Nexxo
    23 Oct 2001
    No worries, I have friends who I can ask. :)
  15. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I should do this for copper since I'm bending it for KR. I should move it over and work on it.
  16. B NEGATIVE
    8 Aug 2011
  17. Deblow
    Deblow Minimodder
    12 Dec 2013
    Thanks for the guide, im just waiting for the cost to go down a bit
  18. B NEGATIVE
    8 Aug 2011
    OP Updated.
  19. TekLord
    TekLord Tek by Design
    7 Jan 2012
    Great guide. I will definitely put it to use.
  20. Etonia
    Etonia What's a Dremel?
    28 Nov 2013
    Great guide, really useful - thanks.
