Modding Adding a expansion slot??
Discussion in 'Modding' started by BigBig5, 14 Jan 2013.
  1. BigBig5
    BigBig5 Single Braid Sleeving
    28 Apr 2010
  2. Guest-23315
    Guest-23315 Guest
    Might fit size ways on above the PSU attached with a ribbon cable..
  3. exiled
    exiled What's a Dremel?
    17 Jul 2012
    or just buy another itx case that would solve the issue
  4. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    or in the space reserved for the dvdplayer?
  5. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    At least show us your setup to see what space you have to play with, can get a flexible expansion card and mount it somewhere inside if space allows
  6. jay2
    jay2 Indonesian Modder
    3 Oct 2012
    Can you mod, move your PSU near to audio jack?
    cut those barrier next to psu
    If i'm using half profile gpu that have card length less than 17cm, i can make it fit that case.
  7. improprietary
    improprietary FT03 is a bitch to watercool
    13 May 2011
    remove the cd drive tray and hard drive caddy, move the powersupply to the former disc drive location over and you'll have the possibility of ~four pci half height slots with space above the psu for your hard drives.
  8. BigBig5
    28 Apr 2010
    I can see that might work.
