Notebooks Advice on a sub £450(ish) lappy
Discussion in 'Hardware' started by BigD79, 22 Feb 2008.
  1. BigD79
    BigD79 Gadding about...
    2 Nov 2007
    Hi,
    My sister wants a new lappy, i'm not too gen'd up on laptops so thought i'd ask you peeps :thumb:.
    Any advice on what makes/shops to avoid or recomnedations?
    She'll be using it for browsing mostly, looking around the £400 - £450 mark, needs wifi and a DVD RW probably need a (cheap) printer too if any come to mind?
    Thanks in advance for your thoughts.
  2. kenco_uk
    28 Nov 2003
    Dell Inspiron 1525 or Vostro 1500.
    A fair range of specs, which you can chop and choose.
    I've never had bother with both Acer's I've had. Toshiba are good. The HP I briefly had was a bit noisy and suffered with overheating a handful of times, however a bios flash seemed to solve most issues. The Dell I have atm is pretty amazing (see sig), although it would stretch your budget a fair bit, you definately get a fair bit of oomph for your money (it was £587 all inc.).
  3. BigD79
    2 Nov 2007
    Thanks Kenco, didn't think about Dell, i'll have a look. Ta.
  4. Krikkit
    21 Jan 2003
    Look for anything with 2GB of RAM, and, more importantly imho, anything with a proper Core 2 Duo processor - most low-end lappys come with smelleron's.
