Build Advice Advice on my new build?
Discussion in 'Hardware' started by rmagro, 9 Jul 2012.
  1. rmagro
    rmagro What's a Dremel?
    25 Feb 2010
    Hi everyone,
    I have been looking around and think that I have found a good combination of parts for my next build, but am looking for some expert advice.
    It will be used for photo/ movie editing, playing games and a bit of everything else.
    Below is what I am thinking of buying... (I already have a 2TB and 500GB hard drive that I will be using for all my data)
    Gigabyte GA-Z77X-UD5H Motherboard
    Intel Core i5 3570K
    8GB (2x4GB) Corsair DDR3 Vengeance Jet Black, PC3-12800 (1600)
    120GB OCZ Agility 3 SSD (for OS and Apps)
    600W Corsair Builder Series PSU
    Corsair Carbide Series 400R Case
    A few questions I have.
    1) Will I need a 120GB SSD or should I just get a 60GB (it will be for the OS and Apps) or should I just spend a little extra and keep the 120GB?
    2) As you probably noticed I have yet to chose a graphics card, what would your advice be to complement the above build (max £300)?
    3) I am never sure about buying power supplies. Is the above PSU good enough for what I will be using?
    Thanks for any help.
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
  3. maestro0428
    maestro0428 Master Modder
    24 Jun 2010
    Your power supply is a bit skimpy. I would go for more like 650w from Corsair or Seasonic. 120GB is the way to go for your SSD. For graphics I would go with a HD7870 unless you want to do some multi monitor gaming.
  4. rmagro
    25 Feb 2010
    Thanks for the replies!
    I will definitely stick with the 120GB SSD, I might fill it up one day.
    maestro0428, cheers for the advice, I'll have a look at some better power supplys.
    I don't think that I will be getting another monitor anytime soon, so I will have a look at the HD7870.
    :thumb:
  5. Harlequin
    Harlequin Modder
    4 Jun 2004
    personal choice would be to look at either a crucial m4 128gb or a samsung 830 128gb SSD rather than the agility 3
