Case Mod - Complete ⭐ Aero Cube
Discussion in 'Project Logs' started by dirkkramer9, 8 Jul 2017.
  1. dirkkramer9
    dirkkramer9 Dkmodding.nl
    31 May 2015
    Hey enthusiastic PC builders,
    I'm going to start a new casemod, this time a micro-ATX build in the Aerocool DS cube.
    It has to be an HTPC that can also be used as a LAN-box, so it has to be a freaking awesome case.
    I started this case mod a few weeks ago but this forum had a little upgrade.
    So there are some more pictures as normal.
    Hardware : not known yet
    Cooling components: Not known yet
    Here are some pictures of the Aerocool DS Cube.
    I started making a midplate and some minor adjustments to the case itself ;):
    Pre-drill the holes and then cut out with the cutter.
    Mid plate fits perfectly :D:
    I made a window in both side panels, here you can see the graphics card en later the cooling en hardware.
    Problem ?? Little space for power cables,s o I did a little adjustment.
    Did some wrapping on the midplate with some mat black.
    I got the idea of making a pump with reservoir combo in the front of the case, so the round hole has already been made.
    Had two more pass through fittings spare, so I used them to make an easy connection through the midplate.
  2. dirkkramer9
    31 May 2015
    Hey, another update.
    This week I started with the front panel of the case.
    I used the Asus Mayan pattern for the front, later on there will be a lot of RGB led`s behind this panel and case parts.
    Used some primer, more in the next update
    If you have any questions, I'd love to hear those :D
  3. DjangoSoe
    DjangoSoe What's a Dremel?
    15 Jun 2017
    What tool did you use for the small cutouts in the Mayan pattern?
  4. dirkkramer9
    31 May 2015
    I used a drill and a Fretsaw. :grin:
  5. Cheapskate
    13 May 2007
    Respect earned. That's a HELL of a lot of hand cutting.
  6. dirkkramer9
    31 May 2015
    I got a new tool for modding, bought this airbrush starter-pack with some paint to get started.
    For a first time I did a nice job I think, of course there are some points we can improve but we can work on that.
    These colors I`m going to use on the case. (red madder dark, black)
    First I used the color (red madder dark), then I used a airbrush and brush and added the color (black). And added a clear coating, for a first time I did a great job I think.
    The sharpness of the pictures will improve in the next update.
  7. dirkkramer9
    31 May 2015
    So I got two packages last week, one with all the hardware and one from Highflow.nl with all the cooling parts. So let`s get started with the inside.
    MB: Asus ROG Strix Z270G Gaming
    CPU: Intel Core i7-6700K
    GPU: Asus Strix GTX1070 O8G Gaming
    RAM: Avexir ROG Tesla Red 2666 MHz 16GB
    PSU: Corsair RM850I
    And of course ''CableMod''
    For cooling I chose EKWB
    EK-FC1080 GTX Strix – Nickel with a shinny Nickel Backplate
    EK-Supremacy EVO – Nickel
    A group photo
    It`s time for some PETG bending
    EK-XRES 140 DDC 3.2 PWM Elite – incl. pump
    Best handy tool ever, no sharp edges anymore.
  8. dirkkramer9
    31 May 2015
    It took a while but here is the final shoot of this Small Case Mod.
  9. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Steady hand and a lot of dedication! i like that in a man... i like it in a woman more! amazing work mate very very cool:dremel::thumb:
    dirkkramer9 likes this.
  10. dirkkramer9
    31 May 2015
    Thanks man, really appreciate it :grin:
  11. kim
    kim hardware addict
    10 Jan 2016
    very clean and nice work with the front grill, final result is great:thumb::clap:
  12. LePhuronn
    LePhuronn Minimodder
    6 Oct 2016
    That hand cutting the Mayan pattern is insane! Massive kudos to you for that. But I gotta say though I really don't like your tube routing. Compliments for achieving so many bends, but it looks so haphazard and detracts from the precision of the rest of the build.
  13. dirkkramer9
    31 May 2015
    Thank you :grin:
    Thanks for the kudos, I understand and I will certainly do something with this in future projects. :thumb:
