Windows Aero stopped working
Discussion in 'Tech Support' started by PAULWARDEN, 9 Nov 2013.
  1. PAULWARDEN
    PAULWARDEN New Member
    25 Apr 2009
    Hi guys for some reason aero has decided to stop working on my pc have done some looking around but none of the fixes i have tried have worked i have even tried microsofts fixit but it states my gpu is not capable of running windows aero . Will it be best to reload windows or does someone have a fix that will work ,in event viewer WMI shows error event id 10 these are the details + System
    - Provider
    [ Name] Microsoft-Windows-WMI
    [ Guid] {1edeee53-0afe-4609-b846-d8c0b2075b1f}
    [ EventSourceName] WinMgmt
    - EventID 10
    [ Qualifiers] 49152
    Version 0
    Level 2
    Task 0
    Opcode 0
    Keywords 0x80000000000000
    - TimeCreated
    [ SystemTime] 2013-11-08T19:02:36.000000000Z
    EventRecordID 62477
    Correlation
    - Execution
    [ ProcessID] 0
    [ ThreadID] 0
    Channel Application
    Computer paul-PC
    Security
    - EventData
    //./root/CIMV2
    SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99
    0x80041003
  2. Deders
    Deders Well-Known Member
    14 Nov 2010
    Is this after updating the graphics driver?
  3. PAULWARDEN
    25 Apr 2009
    yes but even though i have gone back to the old drivers it is still happening
  4. Deders
    14 Nov 2010
    Which drivers did you go back to? does 320.49 work?
  5. PAULWARDEN
    25 Apr 2009
    was working with 327.23 drivers now does not just downloading 320.49 to try
  6. PAULWARDEN
    25 Apr 2009
    tried 320.49 still doing same thing think i will try a fresh install of windows and see if it still does the same
  7. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    If it helps you can ignore the //./root/CIMV2 event as this problem happens on all Windows 7 PC's once SP1 is installed, a Fix It can be found here although it doesn't strictly fix the problem just filters the event log so you no longer get //./root/CIMV2 events showing up in the logs.
    As for having no Aero is the Windows Management Instrumentation service running ? if not what happens when you try to start it ?
  8. PAULWARDEN
    25 Apr 2009
    if i open cmd as administrator then type in net stop uxsms then net start uxsms aero starts until i close the cmd box then stops right away
  9. Corky42
    30 Oct 2012
    uxsms isn't the Windows Management Instrumentation service, its the Desktop Window Manager Session Manager service.
    Are both of these serves set to start automatically ?
    If you want to do it via a command prompt, "sc config uxsms start=auto" and "sc config winmgmt start=auto" but imho it easier to do it via computer management (right click my computer icon on desktop)
  10. PAULWARDEN
    25 Apr 2009
    yes both are set to start automatically
  11. Corky42
    30 Oct 2012
    This feels a little like pushing a stone up a hill ;)
    Are both service running ?
  12. PAULWARDEN
    25 Apr 2009
    yes both are running with no appreciable effect i think i will just wipe the drive and reinstall and get back to you if it is still doing same thing in which case i think it will be my gpu on the way out although sayi g that it does same thing no matter what gpu i use as i have 2 n560gtx-448 cards
  13. PAULWARDEN
    25 Apr 2009
    for some reason nvidia 3d drivers were responsible which is strange as i have never actually downloaded them when updating drivers for gpu always do clean instal and untick the 3d parts
