Hardware Aerocool X-Predator X1 review
Discussion in 'Article Discussion' started by brumgrunt, 5 Oct 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. Krikkit
    21 Jan 2003
    Not my favourite-looking case of all time, but that system of fan/drive mounts looks quite good!
  3. stupido
    stupido What's a Dremel?
    30 Nov 2009
    On the first page the "CPU cooler clearance 115mm" looks not correct...
  4. Speed
    Speed Multimodder
    13 May 2004
  5. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  6. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Off topic slightly but as you linked to it in the conclusion I thought you should know that Scan no longer sells the Antec One so could you recommend a different alternative please?
  7. Dogbert666
    17 Jan 2010
    The case recommendation remains the same, but Amazon have the Antec One in stock for £44.99 :)
    http://www.amazon.co.uk/Antec-One-Midi-Tower-Case/dp/B006TVQU6C
  8. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    If i was a stormtrooper I would buy this case ;)
  9. SchizoFrog
    5 May 2009
    I'd prefer to use some blue lighting and add some blue details and go for the R2-D2 look.
  10. Paradigm Shifter
    10 May 2006
    I've seen far worse for a lot more money, when all is said and done. Not something I'll be buying, but I would imagine that it would perform much better with all the fan mounts filled - even with low-speed fans to save delicate ears. ;) For a start, a pair of 140mm Fractal Design 1k RPM fans on the side would probably drop temps a lot.
  11. S1W1
    S1W1 Minimodder
    25 Mar 2011
    I actually really like the look of the case.
    Just me?
  12. ec928
    ec928 What's a Dremel?
    9 Oct 2011
    Another generic cheap rubbish case review. CustomPC/Bit-Tech, not all of us are unemployed or students with no income. You review high end GPU's costing hundreds of pounds, so where are the 'equivalent' high end case reviews, why this obsession on ONLY low end kit when it comes to cases?
  13. Speed
    Speed Multimodder
    13 May 2004
    There are quite a few high end case reviews if you look but as with anything a balance must be achieved. Most of the users of this site would not spend £200+ on a case, so personally the balance is pretty well thought out imho.
    If you want reviews of other cases just... Google?!
Tags: Add Tags
