AGP and PCI sockets
Discussion in 'Hardware' started by pigcow, 26 Jan 2004.
  1. pigcow
    pigcow What's a Dremel?
    18 May 2003
    Hello. I have a spare gfx lying aroung and i have seen a PCI to AGP adapter somewhere in the USA. are there any other ways of hooking up another AGP card or does anyone know of a place in the UK where a PCI to AGP converter can be bought. Thx for the help :D
  2. ////\oo/\\\\
    ////\oo/\\\\ Minimodder
    16 Oct 2003
    Are you sure it is not an AGP to PCI adapter? This would make more sense as AGP is much faster than PCI...
  3. pigcow
    18 May 2003
    well i think it is, not 100%, cant find site again. bsically i have got a good gfx in the AGP slot and want to somehow hook up another AGP card, just for running another monitor, otherwise ill run both off the same gfx. Thx
  4. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Ok, apparently there's at least one PCI->AGP converter, but the graphics card would have jack for bandwidth, plus you need to find a low-profile card. My guess is that this converter is either ridiculously expensive or impossible to find. Meanwhile, PCI GFX cards are cheap.
  5. Ardentfrost
    Ardentfrost What's a Dremel?
    22 Jan 2004
