AHCI or not?
Discussion in 'Tech Support' started by NickElliott, 4 Oct 2008.
  1. NickElliott
    NickElliott What's a Dremel?
    21 Jul 2008
    I've just setup a new PC and have installed 64-bit Linux with the plan being to setup XP 32-bit & Vista 64-bit as virtual OS's.
    In the BIOS I selected AHCI mode because I read somewhere that this was the way to go and assume that there are performance benefits through things like Native Command Queuing etc.
    Before I go any further does anyone know of obvious reasons why using AHCI mode should be a problem?
  2. naokaji
    naokaji whatever
    8 Dec 2006
    From what i've heard you will end up having to reinstall windows to make use of the extra stuff, however I have no idea if that applies to linux as well.
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    There are ways round that if you have an ICH8R or ICH9R southbridge. For me, the possible advantages didn't seem worth the messing (and risks).
  4. NickElliott
    21 Jul 2008
    Not really a problem in my case as this was a new build so nothing was installed, as you say the risk could be switching to AHCI afterwards.
  5. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    Using AHCI made my 2k8 install take ~15s longer to boot.. but that could just be the mobo I was using.
