Aint Dremels fun!
Discussion in 'General' started by PaulW, 18 Feb 2004.
  1. PaulW
    PaulW What's a Dremel?
    2 Feb 2004
    Just wasted 3 cutting discs :wallbash: :lol: I've never used one of these, so i'm practicing on an old case, will have to buy more discs for it before the week is out! hehe
    I'll get some pics up later, I'm just having too much fun!!! :hehe:
    :rock: :dremel: :rock: :dremel: :rock: :dremel:
  2. Lazy
    Lazy Meow?
    13 Nov 2001
    are you using the carbon fibre ones?
    it will take you hours to cut a window with the standard ones that come with the dremel.
  3. PaulW
    2 Feb 2004
    There standard cutting discs, and yeah its taking ages to cut a small little square out!! Plus it just cost me Disc number 4 :lol: so think I best call it quits for now hehe
    Ok I know it aint a Proper Dremel, but this one is just as good & comes with quite a few extra's to boot!!
    Only problem was the shaft which the cutting discs are connected to spins freely (dodgy shaft) so just soldered it up a bit to stop the play & it works perfectly!
    I think its cos I don't really have a steady hand that there breaking like they are, but I will invest in some of these carbon fibre ones if there as good as you say!! just hope they don't break as easily mind!!
  4. Monkeyboy
    Monkeyboy Minimodder
    13 Dec 2003
    Are you applying too much pressure? Use a light touch, and take your time.
  5. Krikkit
    21 Jan 2003
    If you keep on breaking disks, try changing the speed (if you can), usually a higher speed will help a bit afaik... :)
  6. Ubermich
    Ubermich He did it!
    21 Jun 2002
    go get the fiberglass disks.
  7. AcEmAsTr
    AcEmAsTr Banned
    26 Nov 2003
    your obviously doing something wrong, maybe moving the discs up and down, or too much pressure, ive cut my steel case up lots of times, only problem i get is the discs wearing down
  8. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    if you do it proper you should end up with a nub of a disk...
  9. hypocrisy86
    hypocrisy86 Banned
    27 Jan 2004
    Bad ass :thumb:
  10. MrDT
    MrDT fapfap
    14 Jun 2002
    out of interest, how much did it cost? where did you get it from?
    thinking of getting an el cheapo dremelalike for tiny little jobs (no point shelling out loads of cash for something that will very rarely be used)
  11. Adolftitler
    Adolftitler What's a Dremel?
    12 Jan 2004
    AAAAAAAAAAAAAAARRRRRRRRRRRRRRRRGGGGGGGGGGGGGGGHHHHHHHHHHHHHHH! CHALLENGE EXTREME, SPAWN OF SATAN!! Argos own brand, 30 note. Seriously injured my thumb with one of those after finding the screwdriver wouldnt fit the notches on the tool, so i used a knife! Ruinded all of the cutting and sanding disks and then returned it to my mate who works at argos. I'm much happier with my dremel now.
  12. PaulW
    2 Feb 2004
    I've got a proper set of dremel tools for it now, much better!!! I still think its ok though!!
    I was probably applying far too much pressure, been cutting a few bits lately (with the cheapo-discs & the dremel ones) and didnt smash 1!! was great :D
    Also speed is adjustable, so turned it up a bit & went through alot easier!
    but yeah, the standard tools & bits which come with it are useless!! the 2 drill-bits are buckled & the grinding blocks just keep breaking up, hence the proper dremel bits!
