Graphics air cooling at its best
Discussion in 'Hardware' started by Mister_Tad, 8 Mar 2004.
  1. Mister_Tad
    27 Dec 2002
    in preparation for the upcoming volt mod
    the heatsink on the core is the stock from a P4 3GHz (copper base) butchered up a bit and the ramsinks are chopped up socketA alu heatsink
    the electrical tape on the back of the duct serves as a gasket to sleal up against the back of the case and a 50mm fan brings in fresh air and blows it sideways over the heatsink
    the other electrical tape is because when i superglued the fan in the duct it made the plastic go all gooey and nasty so i just made it a bit more sightly
    results soon...
  2. Hiren
    Hiren mind control Moderator
    15 May 2002
    Ah Josh I see you've gone ahead with adding more heatsinks to PC components. Looking good. The black tape adds a nice "ghetto" touch to it. Don't suppose you need a volcano 9 for your next air cooling idea?
  3. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    Holy Heatsinks Batman! :jawdrop:
  4. Mister_Tad
    27 Dec 2002
    my soundcard looks a bit bare :naughty:
  5. M_D_K
    M_D_K Modder
    3 Apr 2002
    that is a bad ass sink you got there nice one :D
    morgan.
  6. Guest-16
    Guest-16 Guest
    make sure you support it or youll loose chips or the agp bracket.
  7. olv
    olv he's so bright
    23 Sep 2002
    Dear god! That is a monster! only 50mm fan though? I would have thought 120mm at least ;)
    How is the gpu heatsink attached? thermal adhesive? whats that amount of weight like on the card?
    Nice work. i think it's quite classily doen, looks good :thumb:
  8. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    nice work man, what are you going to put on the southbridge though? :D
  9. Mister_Tad
    27 Dec 2002
    i think the duct goes some way to help support the card, the ramsinks are relatively light, rofl at the ram falling off, see how that stands up to an RMA :lol:
    was considering a bigger fan but i had teh 50mm one to hand (came off the heatsink i cut up for the ramsinks) and it *only* takes up 2 extra slots with the 50mm, the gpu sink is attatched using the 4 bolt holes around the core, and a home brew mounting bracket, teh card is freaking heavy with this on, the cooler is many times the weight of the card, but it isnt bowing at all when it is in the case so i guess that is a good sign :worried:
    ROFL, i just had a curious look at the southbridge and some heatsinks i have for the sake of it and it looks like the gfx card heatsinks actually would interfere with anything higher than 1cm or so on the SB, hehe :D
  10. Xen0phobiak
    8 Aug 2002
    can we have a pic of it in situ?
  11. Mister_Tad
    27 Dec 2002
    as per your request sir...
  12. Tim S
    Tim S OG
    8 Nov 2001
    Looks sexEH, as bindEH said though, make sure it's supported fairly well :D
  13. Guest-16
    Guest-16 Guest
    Cheers :)
  14. TMM
    TMM Modder
    12 Jan 2004
    overclocking soundcard? now thats an idea :naughty:
  15. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    rofl:p
    I agree. F ME. wow man. That card must break yr agp slot. it prop need support.
    May I ask. What did you use to stick the ram sinks on>
  16. RR5
    RR5 What's a Dremel?
    7 Dec 2003
    Come on, why just stop there? You can add atleast another 80mm fan.
    Get creative and make a fan box, mount like 4 fans and pipe the air over that heatsink. Perfect excuse to buy plexiglas or lexan and make a duct. :dremel:
    Now I want to see the performance gains. Or maybe the card would just sit around all day and night complaing about how much it weights. :lol:
  17. Mister_Tad
    27 Dec 2002
    a small drop of superglue in each corner and AS3 in the middle
    as for the results:
    before
    max overclock: 565/1012
    idle temp: 45C
    max temp: 82C
    after
    max overclock: 575/1020
    idle temp: 27C
    max temp: 48C
    not a huge gain on the overclocking side but my previous *benchmark only* clocks can now be *all the time* clocks, which is nice :D
    and the new temps should leave anough headroom for the voltmod as well
  18. Tim S
    Tim S OG
    8 Nov 2001
    :D:D
    Nice temps by the way mate :eeek:
  19. Sc0rian
    23 Feb 2003
    oh....really?...hmm..ok
  20. Mister_Tad
    27 Dec 2002
    um, yeah, really
    why not?
