Cooling Air duster!
Discussion in 'Hardware' started by wst, 6 Jun 2017.
  1. wst
    wst Minimodder
    30 Aug 2009
    It's that time in my PC's life when the fans are held still and I unleash all hell with a can of compressed air again - what do people use/recommend? I've borrowed an air compressor other times, to sensational effect. I can't do that this time. Do cans have enough oomph to get what is frankly, a fairly disgusting PC, clean?
    And where do people get it? Is 6 quid a can fairly reasonable, or am I going to get through 10 cans doing this?
  2. Vault-Tec
    30 Aug 2015
    For anything that isn't static sensitive use a paint brush. Fans, heatsinks (removed) etc.
    Never used air myself. Then when you are done just vacuum it all up.
  3. Big Elf
    23 Apr 2009
  4. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    I bought one in 2015, never looked back. But then I do use it every week, not sure if its a bit ott for the people who just clean their pc's out twice a year, would take a good few years to get your moneys worth.
  5. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
    Could just use a foot pump, like the ones to blow up a air bed.
  6. Gareth Halfacree
    4 Dec 2007
    I usually use a rocket blower. Zero running costs, although if you're cleaning a really filthy machine your hands will be knackered by the end of it.
  7. GeorgeK
    18 Sep 2010
    Another vote for the datavac here - even if you only use it occasionally you'll still appreciate the speed of the thing. Make sure you're holding tight though when you first fire it up!
  8. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Yes yes and yes!
    It has other uses mind you. Cleaning dust from hard to reach places including radiators for example. At least that's how I justified the expense! It's a really good piece of kit. :thumb:
  9. johnim40
    johnim40 Minimodder
    23 Apr 2009
  10. wolfticket
    19 Apr 2008
    Ages ago in a thread like this I speculated that this hand held vacuum cleaner might make a good alternative to a relatively expensive DataVac:
    http://www.blackanddecker.co.uk/en-...-blackanddeckereanz-gb/2016/04/01/18/48/vh780
    In the end I went for it and I'm really glad I did.
    It's maybe a little less ergonomic than a DataVac for blowing (it's intended primarily to suck so blowing means attaching a tube to the rear) but being 780W it has a seriously powerful blow and there are plenty of attachments that make up for the lack of ergonomics on the main unit. I use it for computer stuff, but also to dry my bike, as a leaf blower, airbed inflation and general dusting.
    It's never been used as a vacuum cleaner. The only time I use it to suck is to deflate stuff and to vacuum pack stuff.
    Well worth the (as I recall) under £40 I paid for it.
  11. wst
    wst Minimodder
    30 Aug 2009
    I think I'm leaning toward the low-budget solutions suggested. I have (somewhere) a football adaptor that'll go in my bike stirrup pump. Should be enough speed to get rid of the stubborn stuff, I can refill the tank by eating pizza, and I'm a student so £90 is a bit rich for me ;) Thanks everyone!
  12. legoman
    legoman breaker of things
    28 Feb 2010
    Paintbrushing air compressor does the job for me, that or the rocket blower gareth uses.
  13. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    If you want something dual purpose, get a shop vac that allows you to attach the hose to the air outlet. If you want something multi-purpose, a proper air compressor just can't be beat; I bought one ~10 years ago and now can't imagine life without it. Just keep in mind that it can be a bit of a gateway drug, before long you'll be wanting nailers, impact guns, die grinders, air chisels, etc.
    edit: post 1337 :D
  14. Yaka
    Yaka Multimodder
    26 Jun 2005
    go for metrovac, not regretted getting mine also comes in handy when i decide to give my motorbike a bath, great for drying out the awkward spots before a coat of acf50
  15. bladecs_04
    bladecs_04 What's a Dremel?
    5 Jan 2011
    Ive used the 400ml cans to great effect on pcs that havent been cleaned for a few years (1 inch of dust on everything) and I could get 2 PCs out of 1 can.
