A/V AKG K240 mkii - weird audio problem
Discussion in 'Hardware' started by David, 18 Aug 2020.
  1. David
    7 Apr 2009
    My youngest has a pair of AKG k240 MkII headphones, and he came to me and said the sound started to go funny. Sure enough, when I tried them, part of the audio sounds muffled/distorted like it's underwater.
    There's no obvious signs of damage to the headphones so I got another cable. Same problem.
    I sent that back and bought a different cable - problem persists.
    If I pull the plug out 2 to 3 mm it sounds fine, but it's literally sitting so loose in the jack that the weight of the cable alone can pull it free. The original cable is the same.
    I'm confused - any ideas?
  2. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    I don't have those, but my thoughts are;
    - Dry solder joint somewhere in the headphones, probably around the jack area.
    - Buggered jack
  3. David
    7 Apr 2009
    Can't be a buggered jack - this happens on whatever 3.5mm jack I plug it into, regardless of what cable I use. Bear in mind it sound fine when I pull it out a couple of mm.
    That's why I'm confused
  4. Vault-Tec
    30 Aug 2015
    OK.
    Are the headphones 4 prong? is the socket 4 prong?
    It will likely be a combination of the two if one is 3 pin.
    I have had that issue with modern headphones in the past, and sockets etc.
  5. Vault-Tec
    30 Aug 2015
  6. David
    7 Apr 2009
    You mean four pole vs three pole 3.5mm jack plug?
    It's a three pole cable, but they've been working fine on the same PC since last August
  7. Vault-Tec
    30 Aug 2015
    Hmm. Deoxit?
  8. liratheal
    20 Nov 2005
    Oh, I meant buggered on the headphone side.
  9. David
    7 Apr 2009
    Deox what though?
    The cables are new - it happens on whichever device I plug them into and, if it was a problem at the headphone end (which is clean), why would backing out the 3.5mm jack a couple of mm fix the audio?
    See what I mean about confusing? It doesn't make sense.
  10. Vault-Tec
    30 Aug 2015
    The socket? maybe it's got some oxidisation on the pins inside?
  11. liratheal
    20 Nov 2005
    I'd be wrist deep in screwdrivers and teardown instructions at this point, but that's just the kind of weirdo I am.
  12. David
    7 Apr 2009
    I can see the three pin connector clearly - the pins and the contact plate are bright and clean. Again though, if that was the problem, how/why would this be affected/rectified by backing out the jack at the other end of the cable? I'm at a loss to grasp the possible causes of this.
  13. Vault-Tec
    30 Aug 2015
    I have had this issue before. The pins on the male end pretty much can't be damaged ever. However, the pins inside can.
    There is one way I can think of to determine if the socket is damaged. You know how you said if you pull it out a bit etc? well do that and then run a proper stereo test (where it tests left and right speakers). If it is not running MONO through a short (which is usually what happens when you pull out like that (*sniggers* :D ) then it is highly likely the socket.
    If it still runs in stereo like that? it's probably still the socket. I have read through this three times and just so I am not being a total idiot have you tried the headphones on something else?
  14. David
    7 Apr 2009
    Like I said, the pins in the socket on the headphones are clean and straight - there is no obvious issue with that socket. the OTHER end of the cable (the 3.5mm audio plug) is the one I have to back out of the port a few mil to get decent audio. It is in stereo.
    I have been through three headphone cables and the problem persists. I have tried the headphones on my son's PC onboard audio, and with a USB sound card. I've also tried them on my PC, onboard and with a different USB soundcard.
    Nothing about this makes sense.
    I've been through the usual processes of eliminating possible causes - three cables and four different audio sources. I'd normally be pointing at the headphones as damaged/faulty but when I can get seemingly perfect audio by manipulating the opposite end of the cable, any cable, it throws doubt on why the headphones are the source of the fault.
    I was wondering if it was an impedance issue, but how that would manifest and why it would suddenly appear is beyond me.
  15. liratheal
    20 Nov 2005
    Hum.
    I still suspect the jack on the headphones, sounds like something is misaligned/iffy if twiddling the other end 'fixes' the problem.
  16. Big Elf
    23 Apr 2009
    Probably the socket based on my limited experience. I have exactly the same problem with the socket on the back of my TV. Like you I went through a few different cables, all with the same result.
  17. FILIPE MALISKA
    FILIPE MALISKA What's a Dremel?
    30 Jun 2021
    Same headphone and same problem!so weird
    Did you solve the problem?
