Watercooling Alpine White TJ07- Water Cooled - Pictures
Discussion in 'Hardware' started by bdigital, 9 Sep 2012.
  1. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    They sound very nice. Any pics? Dont worry if not. Drop me a pm if your interested in selling them :)
    Il try both those and paula ones just to make sure i get the best look
  2. David
    7 Apr 2009
    Yeah, I have one, that's why I asked - I could imagine the red LEDs spoiling the effect somewhat. To be fair, it would take a lot to spoil it, mate. :thumb:
    YEHBABY likes this.
  3. bdigital
    10 Aug 2010
    Well i originally had one with all blue LEDs. But come installation day the LEDs packed up working??! So then i bought this one from parge.
    Its on the to do list mate, cant be doing with a red light in the mix lol
  4. Big Elf
    23 Apr 2009
    They're natural finish rather than white, similar to the cable housings
  5. bdigital
    10 Aug 2010
    I would like to try them if you are wanting to sell? But they will be up against the ek easy mount ones.
    If your not keen on selling then thats fine :)
  6. Big Elf
    23 Apr 2009
    I can send 1/2 dozen anyway but the easy mount looks good and would be even better powder coated white. I've got your address so I'll send them later this week.
  7. Guest-56605
    Guest-56605 Guest
    I'm with Steve on this :thumb:
    Good job I'm sending 2 sets of domes ;)
    You can have one set powder coated white and keep one set in nickel :D
  8. brave758
    brave758 Minimodder
    16 Apr 2009
    wow mate just wow
  9. jammy_fred
    jammy_fred Minimodder
    26 Jan 2010
    Attention to detail here is just fantastic, not a single thing wrong. I particularly like that GPU backplate.
    Awesome pics too.
  10. Gurdeep14
    Gurdeep14 Minimodder
    25 Apr 2009
    Just made an awesome build even better :) Well done
    Seeing your initial build was what made me finally buy a TJ-07
  11. bdigital
    10 Aug 2010
    thank you very much :) although i must say im not 100% content yet! I will be back with somw better external pics when i can figure out the lighting.
    Glad you like it Gurdeep - fantastic case with so many options.
    Margo Baggins likes this.
  12. paz45
    paz45 What's a Dremel?
    12 Nov 2010
    First class job Bobby turned out fantasic
    glad to be of some assistance:thumb::thumb:
  13. scott_chegg
    scott_chegg Minimodder
    16 Feb 2010
    Skills Bobby. That's one good looking rig you've built!
  14. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    Really nice job bobby. Really love TJ07's, I have been wanting to get one for years!
    + rep
  15. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    what rad are you running and that are temps like?
  16. bdigital
    10 Aug 2010
    Im using an Alphacool UT60 480 (Quad rad).
    The GPU is overclocked as far as cc will allow (stock volts) and i cant get it to run higher than 46c - really happy with that one!
    The CPU tops out at 65c in prime 95 on 1.375v at 4.8 with HT on.
    Fans on lowest speed.
    I have not yet had time to check the mobo temps that will be next!
    Its fair to say that i will be able to refine the cpu overclock somewhat and will probably disable HT so i think i will be able to drop the cpu temps down a fair bit.
  17. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    thanks:thumb: i think a UT60 is going to live in the basement of my tj-07:)
  18. bdigital
    10 Aug 2010
    Your welcome. Im very impressed with it so far. It performs well with fans at low speed and its all copper design gives it the edge over the competition at a very competitive price point.
    Couldnt of done it without your help Paz - thank you very much
    cheers scott much appreciated.
    Thanks Margo - go for it! They are great value and well built, they will last many rebuilds! :)
  19. oliverr97
    oliverr97 What's a Dremel?
    31 Jul 2011
    Wow, this build looks amazing. I'd build something like this but I have no DIY skills at all :)
  20. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    All the waiting was finally worth it!Cracking job mate, doesn't look like many compromises made there
