Graphics Am I just being stupid?
Discussion in 'Hardware' started by Anator, 13 Mar 2006.
  1. Anator
    Anator What's a Dremel?
    26 Feb 2004
    Ok, I feel like a bit of a fool for posting this, but I couldn't think of anything else to try.
    Is there something I am missing when it comes to removing wires from a small 2 pin fan connector? I tried for ages to try and remove the wires and eventually ended up tearing it out of the connector, now im left with the connector and 2 very small pieces of wire still lodged in it :waah:
    I need the connector as the new cooler i am fitting was 3 pin, and the socket on my card is 2 pin.
    What am I missing? Surely there is an easier way to remove these wires than tearing them out :geek:
    P.S No comments about noobs please :blah:
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    On the side of the connecter there should be a little bit of exposed metal, push it in with the point of a knife or a small screwdriver, and pull on the wire, the connecter should pull out with it.
  3. Anator
    26 Feb 2004
    Yeh, I did actually try this before but im telling you it would NOT come out! Ill give it another try but unfortunately i have very little wire left to pull on now.
  4. ElThomsono
    18 Mar 2005
    In that case I'd just forget about it and reach for the soldering iron. If you're changing the fan chances are the warranty's out the window anyway.
  5. atanum141
    22 Jul 2004
    what about using a pair of pliers and gently "rocking" the connector out.
  6. Anator
    26 Feb 2004
    I guess your right, was hoping I wouldn't have to though.
    It's not the connector itself im trying to remove, its the wiring from inside the connector (whats left of it).
