News AMD announces 2nd Gen Ryzen CPUs
Discussion in 'Article Discussion' started by bit-tech, 12 Apr 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    "If you don’t need eight cores, AMD offers the 6c12t Ryzen 5 1600X" I think you mean 2600X?
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Also worth noting that (afaik) Ryzen 2 comes with precision boost 2, XFR 2, and reduced L2 latency (or at least the latency Zen was designed to have when it launched (Zen 2 fixes a problem with the original Zen L2 latency being higher than designed, 17 cycles to 12))
  4. Omnislip
    Omnislip Minimodder
    31 May 2011
    Nice to see the (relatively) kickass cooler coming with the top part, and presumably greater efficiency on the 2600 (hence the drop to Stealth?)
  5. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Very nice, what exactly are the differences between the 2600 and 2600X? It seems like you gain 200 MHz clock with the 2600X but with a 40W higher TDP.
  6. RedFlames
    23 Apr 2009
    the same as between the 1700 and 1700x iirc...
  7. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    These processors have the numbers 2600 and 2700, so they must be at least as awesome as the last set of processors numbered 2600 and 2700 or else all is lost.
    The 2700 sounds potentially fantastic for a new work PC, if it's reasonably efficient and doesn't chuck out too much heat all the better.
Tags: Add Tags
