News AMD announces socket AM3 Phenom II processors
Discussion in 'Article Discussion' started by CardJoe, 9 Feb 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    It's useful if you are buying now, and heart-set on using DDR3 for future compatibility (obviously you can run your 1600MHz DIMMs at a slower speed for now) but aside from that, I'd have thought AMD are more-than-likely keen to a) catch up with Intel, b) drive up adoption of DDR3 (and subsequently the price down) and c) avoid locking customers into a memory standard that will eventually become phased-out (however few of them that applies to.)
    It's a good thing really, but the performance isn't the benefit sadly. :(
  3. roshan
    roshan What's a Dremel?
    23 Aug 2008
    AMD really in need of a major core redesign to compete with core i7.DDR 3- 1333 i am sure has not got more juice than DDR2- 1066 because of the latency.
  4. ssj12
    ssj12 Minimodder
    12 Sep 2007
    i hope this means that the Athlon X2 7750BE will drop in price =D
  5. talladega
    talladega I'm Squidward
    18 Aug 2007
    are these AM3 processors the ones that overclock like crazy?
  6. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    So far results are promising on a DDR2 setup the AM3 is performing nearly as well as the i7 using dd3, so I suspect that when the DDR3 mobo come out we should see equal performance or to sum degree better performance, as it is in gaming the AM3 are doing the same or better then the i7 in high resolutions so ya this is looking good.
  7. Yourcomputer
    Yourcomputer What's a Dremel?
    30 Dec 2008
    Sources? I'm really doubting AM3 will bring AMD close to i7. Memory bandwidth really isn't AMD's problem.
  8. HourBeforeDawn
    26 Oct 2006
    http://www.overclockersclub.com/reviews/phenomii_720_810_am3/
  9. Gh0stDrag0n
    Gh0stDrag0n Unleash the Beast!
    16 Aug 2007
  10. Gremlin
    Gremlin What's a Dremel?
    31 Aug 2008
    Any idea on when we will (or might) get the article or how long its been delayed for?
  11. talladega
    18 Aug 2007
  12. HourBeforeDawn
    26 Oct 2006
    but not by to much and when it comes to pricing alone where its practically half that of an Intel build for an AMD build in terms of CPU, Memory, and Mobo, that little bit more from the Intel side for that large of an expense isnt really worth it unless your doing hardcore OCing.
Tags: Add Tags
