News AMD Catalyst 13.8 Beta brings micro-stutter fix
Discussion in 'Article Discussion' started by Gareth Halfacree, 2 Aug 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
  3. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    Good on AMD for getting on it...but I can't recall how long I've been hearing about this problem with CF. And only DX10/11, single-display up to 2560x1600? Better than a kick in the nuts, but damn, AMD, step it up already!
  4. rollo
    rollo Modder
    16 May 2008
    20% is better than 60% but only just
  5. konstantine
    konstantine What's a Dremel?
    18 Jan 2009
    Wow, decent job AMD! I'm waiting for the AMD push to use decent physics in games. Those APUs can do it, and I don't there's another way to handle those computation heavy simulation effects. A decently fast APU is miles faster than the best Intel can and will have to offer in the future for those kinds of workloads.
    Really, the future of gaming rest upon AMD.
  6. thom804
    thom804 Minimodder
    22 Oct 2009
    Fixed that for you
  7. konstantine
    18 Jan 2009
    Well, those upcoming consoles are really low-end APUs with bigger GPUs. The underlying point is: APUs are faster than mere CPUs in those massively parallel workloads. Those consoles will force coders to learn how utilize those SIMD clusters in those GPUs to perform massively parallel vector computations, which what physics and AI workloads look like. Take a look at how much GPGPU is faster than a mere CPU in such workloads. And this what 6 GCN SIMD clusters can do without HUMA.
    http://media.bestofmicro.com/X/V/365395/original/clbenchmark.png
  8. rollo
    rollo Modder
    16 May 2008
    Consoles for the most part will still be coded to hardware, if they want the best performance. Which means we will get ports that are still using direct x. That alone means for us pc gamers you would still need balanced hardware.
    As for physics its not really that important unless nvidia allow it on AMD cards which I have my douts.
    Will be 2 years before we get a good port all the rest will be rush jobs.
  9. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Judging by all of the reviews / analysis, these drivers look like a major step in the right direction for AMD CF. They still have a way to go as compared to a GTX690 the % difference in frametimes is still on the high side (20% compared to 5-10%), but it is still alot better than it used to be.
    Depending on price I may even look at trying out a couple of 9970's in CF instead of a single card. Or I could just slap in another 780....
