CPU AMD Idle Temps
Discussion in 'Hardware' started by andyjh, 18 Aug 2011.
  1. andyjh
    andyjh The Underdog
    26 Apr 2011
    What's everyone running stock?
    My ambient temp is probably around 20'c
    Idle temps on computer is around 30'c and about 57'c when folding.
    Is it running a little hot? I've considered lapping it just incase
    Running stock cooler btw
    Coolermaster Elite 335 case - AMD X4 640 CPU
  2. bulldogjeff
    2 Mar 2010
    Amd CPUs can handle up to about 65 degrees comfortably, so it's not to much of a problem. Idles maybe a little warm but not excessively, so no need to worry really.
  3. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    i think thats fine :) my phenom 2 955 can reach up to 67C when gameing for a couple of hours.... so i think as long as u dont go past 70 u should be fine :)
  4. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    Its not so bad, and makes sense with stock cooler. Like mentionned 60-65 is really the high-end for these chips. Don't bother lapping whatsoever, if you're not happy with that get an aftermarlet cooler. My 955's never gone above 55C under full load @3.8GHz with a Hyper 212+ and it's a very very affordable cooler..
  5. Publ!c Enemy
    Publ!c Enemy or Richard for short
    4 Jul 2010
    I think that those temps are fine. My 965BE at 4GHz (cool 'n' Quiet still on) idles at 36 and under load will reach about 62 max, when i play gta 4 for hours it gets to 59/60:)
  6. KidMod-Southpaw
    28 Sep 2010
    I'm using a thermaltake frio with 2 enermax TB silence fans with a 1055t at stock. That idles at about 13 degrees and loads at 46 under prime.
  7. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    13 degrees, whats your ambient room temperature?
    Do you live in a fridge? :)
  8. OCJunkie
    19 Apr 2011
    13 degrees, lolwut?
  9. andyjh
    andyjh The Underdog
    26 Apr 2011
    Ty, I'll consider upgrading the cooler. I know it's nice and safe but still a little too warm. Although it makes a nice heater in the winter instead of paying the gas bill :D
  10. deadsea
    deadsea What's a Dremel?
    9 Oct 2009
    36 deg at idle. 720 X3. Ambient's around 30? Tropics.
    Undervolted though with one of the ocz coolers. Looking at it, but still no idea.
