News AMD, Intel drop D-Sub support
Discussion in 'Article Discussion' started by CardJoe, 10 Dec 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. adam_bagpuss
    24 Apr 2009
    crap we use VGA over Cat5 to HD TVs quite a lot. HDMI, DVI and display port over cat5 is a lot more expensive !!! DAMMIT.
  3. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    I visit a lot of different companies with my work and often utilise their video equipment whilst I'm there. The one common connection that everyone has on all their machines is VGA.
    Given how fast many companies update their machines, if I rocked up with a laptop that didn't have a VGA socket I'd be very worried. I agree it needs to be phased out, I'm just wary of this sort of situation arising.
  4. Bridaggs
    Bridaggs What's a Dremel?
    11 Oct 2010
    Haven't used VGA for many years, and stopped using DVI a fair old while ago to. I'm surprised this hasn't happened sooner to be honest, at least on a home consumer level anyway.
  5. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    lol once again everyone is ignoring nvidia. its a shame they want to ditch dvi too, but that port is extremely bulky considering that displayport and hdmi can do the same thing but are much smaller, and hdmi has audio output.
    luckily for those who might still want to use older displays in the future, theres still the adapter converters. i haven't seen any displayport to dvi or vga converters, but i'm sure they exist.
  6. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    And DVI differs from HDMI because...
    Sigh. It would be nice if the people writing these press statements knew at least thing one about their subject.
  7. sb1991
    sb1991 What's a Dremel?
    31 May 2010
    Because it generally retains the capability to transmit an analogue (VGA) signal, which they want to get rid of, as well as the digital one.
  8. dworvos
    dworvos What's a Dremel?
    21 Jun 2008
    There's a DVI-D, DVI-A, and DVI-I spec, I'm assuming they want to phase out the DVI-I and DVI-A.
    Unfortunately you'd need an active converter as a passive one won't work (the ones you find in video card boxes are passive, they require a DVI-I or DVI-A signal to be present from the video device).
    There's a wealth of good info on the wikipedia page about DVI:
    http://en.wikipedia.org/wiki/Digital_Visual_Interface
  9. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Aside from the various specs of DVI aspect covered above, HDMI is superior because it can carry audio and takes up less space. In place of two DVI ports on the back of a video card there could instead be three, maybe even four HDMI ports.
    Additionally, read the rest of the article. Part of their reasoning is that DisplayPort will be used for PCs. So DVI isn't actually being replaced by HDMI at all, it's being replaced by DisplayPort. HDMI is used for TVs which rarely have DVI in the first place, though some have VGA.
  10. CharlO
    CharlO What's a Dremel?
    21 Oct 2009
    Nothing that is 1.x is the future of nothing, a 2.0 will come and crush it.
  11. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    this.. with cat5 cable you can go pretty far over analogue
  12. azrael-
    azrael- I'm special...
    18 May 2008
    Just FYI, DVI can carry audio as well. Like with HDMI audio and video is interleaved.
    And connector-wise DVI is vastly superior to both HDMI and DisplayPort. Why? Well, for one you can actually securely attach it with screws. Something neither HDMI nor DP can. Unsurprisingly just like SATA. I've seen my fair share of SATA and HDMI cables pop out of their slots. Good protocols, lousy connectors. There seems to be some sort of competition as to who can come up with the most lousy connector...
    As for killing off the DSUB15 (VGA) connector, no problem. Just keep DVI-I around and all is fine.
  13. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Good to know. Never seen that used, likely because no TV (which HDMI is to be used for) I've seen has used DVI as an video+audio input from a PC. TVs already have a wealth of HMDI inputs available, making PCs be able to use those even in the mainstream market is an excellent move to reduce the number of connectors needed on both ends to ensure compatability with all of a user's potential needs.
    We've also seemed to have the exact opposite of screw in connector experiences. :hehe: I've witnessed a couple incidents from clutzy friends at lan parties who trip on a screwed in cable and ended up taking down their monitor and one time even knocking over a case. Haven't screwed in any cables which may be exposed ever since. And of course if it's not exposed then it shouldn't fall out! But it would seem YMMV on that.
  14. Floyd
    Floyd Wire Twister
    4 Dec 2008
    YAY This news is just as good as floppy, IDE and PS2 ports dropping from mobos!
    Kill off all the legacy!
  15. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    +1... exactly what I was going to say.
  16. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Can't say I blame them, it's very outdated now. My TFT is 5 years old and has digital connections.
  17. supermonkey
    supermonkey Deal with it
    14 Apr 2004
    I remember a short time ago reading that the industry giants were considering phasing out HDMI in favor of video and audio over ethernet. One of the benefits, aside from higher bandwidth, was the open nature of ethernet as opposed to the licensed HDMI standard. Are they now abandoning that idea?
    This just in, Monster has revised its economic outlook to take into account all the $100 phoenix-tail-feather-dipped-in-unicorn-blood cables. It is, after all, the only cable that supports deep color 3D True-HD video on your cheap LCD monitor.
  18. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    IDE still exists though? :(
  19. necroscop
    necroscop What's a Dremel?
    31 May 2010
    Can HDMI support anything more then HD 1080 on all boxes it say max 1920x1080.
    PC monitor market its way ahead of TV market, are TV standards will support monitors like 2560x1600. And in next few years we will see PC monitors with much higher resolution, as demonstrate by Dell. Is this mean I will need 2 or more HDMI cables to run with high resolution or we will have to pay for very expensive HDMI cable which support high resolution.
    What we need its completely new chip standard which will work with everything. What they doing now it next money making scum. As we all will have to buy new HDMI cables even if there its nothing wrong with DVI
  20. Floyd
    Floyd Wire Twister
    4 Dec 2008
    I didnt think you could buy an IDE drive anymore. I thought everything was sata.
    Who would buy IDE over sata anywho?
Tags: Add Tags
