News AMD: Proprietary APIs are bad for industry
Discussion in 'Article Discussion' started by Claave, 19 Aug 2011.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. wyx087
    wyx087 Multimodder
    15 Aug 2007
    @AMD, stop talking. start actually doing something please.
    Proprietary stands work, because the company that benefits from this standard will be pushing it harder than any open standard organisation can ever do. this kind of push is needed for any new technology.
  3. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Wait, hang on, their example of a non-proprietary API is DirectX? By that logic, surely CUDA is an open API too, as anyone can write code for it?
    The only difference between CUDA and DirectX is that one company makes CUDA-supporting chips, and two companies make DirectX supporting chips. At least CUDA is cross-platform (official support on Windows, Linux and OS X), unlike DirectX which only works via Wine et-al on non-Windows systems.
  4. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    I think they're talking from a hardware perspective:
    direct-x - any hardware vendor - open
    open-cl - any hardware vendor - open
    cuda - nvidia cards only - proprietary
    from a software perspective, direct-x goes proprietry for the OS.
  5. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    More than that, strictly speaking.
  6. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    That's exactly the point, how DX isn't locked to a particular manufacturer at the hardware level but CUDA and PhysX are Nvidia proprietary.
  7. Mraedis
    Mraedis Minimodder
    5 Sep 2009
    No.
    There are tons of examples where proprietary didn't work. I don't really think it's open vs proprietary, more being either the first to get widely accepted or being wildly better than the previous dominant one (and getting widely accepted).
    There just isn't a magic formula for these things.
  8. wyx087
    wyx087 Multimodder
    15 Aug 2007
    the first to get widely accepted or the widely better than previous.
    but what happens if both function equally good, and both develop at similar pace? look at iOS vs Android for example. innovate and compete is the answer.
    what does AMD do? they talk a lot.
    (yes, it's not as simple as that, but still, AMD need to put more effort into actually pushing OpenCL if they are betting on it to succeed in the short term. in the long run, im sure OpelCL will overtake CUDA in adaptation)
  9. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    well for instance- nvidia to run cuda in linux.. was simply install graphics driver and compile the software you wanted to use cuda
    amd.. you have to install the driver, install the opencl sdk, before compiling the sdk you have to put in the icd registration files under vendors (I assume this is because any card, even nvidia can use opencl) and then compile the software you wish to use
    there's a few extra steps.. cuda since it works with just nvidia cards, does it all in one.. that's the only thing I see going for nvidia's proprietary standard..
    I do really like how they've pushed it all forward though.. give credit where credit is due :)
  10. Mraedis
    Mraedis Minimodder
    5 Sep 2009
    I won't argue with you there, you make a good poitn, I'm just saying not all proprietary standards just "work". :)
  11. impar
    impar Minimodder
    24 Nov 2006
    Greetings!
    Agreeing with AMD on this.
    Case in point, PhysX. It needs to open up or disappear entirely. It harms the proper development of physics in PC gaming.
Tags: Add Tags
