News AMD readies RV670 graphics chip
Discussion in 'Article Discussion' started by Tim S, 28 Sep 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Guest-23315
    Guest-23315 Guest
    Apparently there are also rumors of an X2950XT coming out in November!
    Should make an interesting christmas!
  3. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    I sure hope so! This generations midrange cards have been very disappointing from both nvidia and ati.
  4. Goty
    Goty Minimodder
    13 Dec 2005
    Unfortunately, that's only out of character for nvidia. ATI's midrange cards are usually fairly disappointing at first with some decent refreshes later on in the cycle.
  5. Cobalt
    Cobalt What's a Dremel?
    24 Feb 2006
    I promised myself that the next graphics card I bought would be 512MB because I am already starting to run into a texture size wall with certain games *glares at oblivion* and I want something that will last as long as my 9800pro did. Maybe that will never happen but I hated that I had to replace my last two cards within a year. It probably won't be untill the next generation of DX10 graphics cards that I upgrade at this rate. The price performance ratio in the current gen is abysmal.
  6. devdevil85
    devdevil85 What's a Dremel?
    29 Nov 2006
    I AM that gap....I don't want a piece of crap, but I can't afford the cream of the crop....it's sad, but mid-range is really the better way to go for me...
  7. EQC
    EQC What's a Dremel?
    23 Mar 2006
    I hope the reduction to a single 6-pin power connector has nothing to do with the PCI-Express 2.0 power allotment -- that would imply that the card couldn't work (or at least wouldn't get enough power to run at full speed) on any of the PCI-Express 1.0 boards that have sold over the last several years.
    Or maybe it draws 150 Watts in total, so on a 2.0 board, you don't even need to plug in the 6-pin connector, and on a 1.0 board, it'll get power through both the motherboard and the 6-pin?
  8. Drexial
    Drexial Minimodder
    28 Jul 2005
    ATi really needs to cook something good up to bring back the competition between the two. hopefully this will help a little.
    Is it also amusing that the watermark on the pictures is nv6800? cause that makes me think of nVidia 6800.... and its a ATi card? no? just me? ok....
  9. sam.g.taylor
    sam.g.taylor Apparently I'm Greg Kinnear
    15 Aug 2006
    that much electricity - and the mid 8-series will still probably beat it.
    So much for ATi being green...
  10. Bladestorm
    Bladestorm What's a Dremel?
    14 Dec 2005
    Manufacturers would be insane to make PCI-E 2.0 only cards anytime in the near future, so I wouldn't worry too much about that.
    Edit add (talk about going off half cocked..)
    I'm waiting for a decent mid-range DX10 card myself, somehow if this is going to be less powerfull than the GTS 640mb/2900 region I doubt its the card for me :(.
    Kinda waiting for Nvidia to come out with 89xx or 9xxx I think, though unless AMD can pull together major competition soon, anything nvidia do eventually release is likely to be hideously expensive still. :duh:
  11. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    ooow interesting I cant wait to see this in real world test ^_^
  12. Aankhen
    Aankhen What's a Dremel?
    15 Oct 2005
    They would have to work pretty hard to make PCIe 2.0–only cards, I think, since PCIe 2.0 is backwards compatible.
  13. Guest-16
    Guest-16 Guest
    Yea it is, and we've heard from more than one source that PCI-Express 2.0 is more or less nil performance increase.
  14. devdevil85
    29 Nov 2006
    single slot cooler = positive / single 6-pin PCIe power connector = positive for some reason I was thinking the GPU was going to be based on TSMC's 45nm process....o well....
  15. completemadness
    completemadness What's a Dremel?
    11 May 2007
    doesn't surprise me, the change from AGP to PCI-E was a pretty low performance gain as well
    The cards are far more limited by other things then the bus
Tags: Add Tags
