News AMD targets 2022 for DDR5
Discussion in 'Article Discussion' started by bit-tech, 28 Apr 2020.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    When are Intel planning on using DDR5?
  3. Paradigm Shifter
    10 May 2006
    Is 16GB the "limit" for DDR4? I've got 4x32GB DDR4 (non-ECC) DIMMs in a box at work, and DDR4 LRDIMMs already reach 128GB with 256GB on the way. Or does LR/Registered/ECC etc not count? Is this single vs. dual rank? Please explain.
  4. wolfticket
    19 Apr 2008
    If you've got a load of money to spend then otherwise fairly ordinary desktop 128GB DDR4 kits that consist of 4x32GB DIMMs certainly seem to be a thing.
  5. RedFlames
    23 Apr 2009
    it could be the JEDEC/'official' limit in the same way DDR4 'officially' tops out at 3200MHz [iirc, might be lower]
  6. RedFlames
    23 Apr 2009
    iirc anything outside jedec specs is just deemed be overclocked
    Guest-44638 likes this.
  7. Anfield
    Anfield Multimodder
    15 Jan 2010
    It was the practical limit for consumer DDR4 sticks for many years, only recently have 32GB ones become readily available.
    The result being that most QVL lists top out at the 16GB sticks and also why support for the bigger ones can be hit and miss in the IMC / Bios.
Tags: Add Tags
