Case Mod - Complete ⭐ AMG PROJECT #CMWS20
Discussion in 'Project Logs' started by Sa mod pc design, 19 Dec 2020.
  1. Sa mod pc design
    Sa mod pc design Minimodder
    7 May 2019
  2. Sa mod pc design
    7 May 2019
    Hi everybody, I’m here to present you AMG Project.
    After Delta and Ferrari I ideated this new project. As always I was inspired by my great passion for motors.
    This is based on Cooler Master Cosmos C700P and the difference with my other works is that I cut the case and I created side pods in 3D.
    I want to thank all my sponsors that made possible this Case Mod.
    Cooler Master
    Asus Rog
    AMD
    Alphacool
    Hyperx
    Kingston
    HARDWIRE-CUSTOM CABLES MAKER
    HYDRA
    TEAM : MODDERS ESTREMI ITALIANI
    COOLER MASTER COSMOS C700P
    POWER SUPPLY COOLER MASTER V750 GOLD
    ASUS ROG CROSSHAIR VIII FORMULA X570
    ASUS ROG STRIX RX 5700 XT AMD
  3. Sa mod pc design
    7 May 2019
    AMD RYZEN 9 3900X
    ALPHACOOL
    hyperx
    kingstone
  4. Sa mod pc design
    7 May 2019
    Hi everybody, today I'm here to show you project's planning in 3D.
    It was an hard work and I spent a lot of time on it. I tried to create what was an idea of a Mercedes AMG in my imagination.
    The hardest work was to match low lateral 3D part on the frontal panel.
    Since I haven't a 3D scanner, I measured all the case manually and then I created it in 3D.
    As you can see by images, I cut case's back part and I did again component's fixing plates.
    I hope my project likes you and I come back when I will finish to print 3D parts.
  5. Sa mod pc design
    7 May 2019
    Hi everybody, today I come back with new upgrades...
    I cut case's back part and I prepared down plates where I will fix green plexiglass plates of hardware that I customized with my signature.
  6. Sa mod pc design
    7 May 2019
    Posted December 2 (edited)
    Hi guys, 3D parts are finally ready and I started to work on them
    I drilled front panel where I applicated Mercedes logo.
    I started to assemble and test 3D parts .
    I installed resevoir and ssd on one of the plates.
    Cheapskate likes this.
  7. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    That is looking really cool :rock:
    Sa mod pc design likes this.
  8. Sa mod pc design
    7 May 2019
    sanded the parts several times and I used spray putty to remove layer 3D.
    After this work, I finished the process of 3D refinement and I used the primer on the parts.
    Now I assembled again bodywork to see how they look with primer.
  9. Sa mod pc design
    7 May 2019
    Hi guys I come back...
    I continued to paint all pc parts.
    I used official opal black paint of Mercedes.
    On the bodyworks I applied AMG logo using official green colour of Mercedes.
    I installed also an auto's metal mesh.
    Now I put Mercedes logo and I started to assemble all.
  10. Sa mod pc design
    7 May 2019
    WHen I finished to assemble, I full custom loop, and I tested all.
    I show you final photos and video and I hope you like it.
    4LIEN, Cheapskate and Jean R built like this.
  11. Sa mod pc design
    7 May 2019
  12. Sa mod pc design
    7 May 2019
  13. Sa mod pc design
    7 May 2019
  14. Sa mod pc design
    7 May 2019
    thanks bro
  15. Cheapskate
    13 May 2007
    Open back design. :worried: Well, there goes one of my designs I've been keeping under wraps. You beat me to it.
    Fantastic build. :rock: The fit, finish and color scheme are perfect.
  16. Sa mod pc design
    7 May 2019
    [QUOTE = "Cheapskate, post: 4863384, member: 31774"] Design aperto sul retro. :preoccupato:Bene, ecco uno dei miei progetti che ho tenuto nascosto. Mi hai battuto sul tempo.
    Costruzione fantastica. :roccia:La vestibilità, la finitura e lo schema dei colori sono perfetti. [/ QUOTE]
    Thanks bro
  17. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Very good work!
  18. Sa mod pc design
    7 May 2019
    [QUOTE = "4LIEN, post: 4863549, member: 887318"] Ottimo lavoro! [/ QUOTE]
    Grazie: clap:
  19. TodMod
    TodMod Minimodder
    14 Dec 2018
    That's awesome bro I love it
  20. Sa mod pc design
    7 May 2019
    [QUOTE = "TodMod, post: 4863975, member: 872729"] Fantastico fratello, lo adoro [/ QUOTE]
    Thanks so much bro
