Education Android phone transfer - when the screen is broken!
Discussion in 'General' started by Pete J, 13 Sep 2023.
  1. Pete J
    Pete J Employed scum
    28 Sep 2009
    Hi all,
    A colleague at work has unfortunately broken their screen on their mobile, and wants to transfer to a new phone via smart switch, but can't click on the relevant button ls as only a third of the screen is working (and unfortunately it's the wrong third). He's already tried connecting an external monitor (which was new to me) but it doesn't mirror the screen.
    Is there a simple alternative way of transferring things? Thanks for any replies!
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    I've recently been through similar here, unfortunately the phone wasn't compatible with any of the options listed.
    Pete J likes this.
  3. VictorianBloke
    VictorianBloke Man in a box
    31 Oct 2007
    Can you just turn it upside down, or sideways to use auto rotate to access the button, or is it one of those annoying pages that refuses to change orientation?
    Pete J likes this.
  4. Pete J
    28 Sep 2009
    Cheers chap, will forward to see if it helps.
    The latter, unfortunately.
  5. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Your friend might have to connect the phone to a PC & use ADB to do things the hard way.
    Pete J likes this.
  6. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Can your colleague not restore from a backup? Most Android phones default to having the Google One backup option enabled as default.
    Pete J and IanW like this.
