Modding another psone lcd question
Discussion in 'Modding' started by plazymburn, 17 Jul 2004.
  1. plazymburn
    plazymburn What's a Dremel?
    11 Jul 2004
    just got mine today, a pal one, and im not happy, how come no-one said it had a mini av in port, i was under the impression i could connect composite straight from my card. second, could someone please tell me what i need to get this thing to work, its a pal sony one, so the thrustmaster wiring diagrams arent much use to me(i think). i called around today and found somewhere that has a composite to mini av cable, going the composite route, does composite turn the screen on or do i have to do the dcc thing, if so can someone explain this for me. and with the composite to vga mod what do i need for it, sorry you've probaby been asked this a thousand times. ive read the other posts from all the sites and i am struggling to make sense of it all. can someone help me please.
  2. plazymburn
    11 Jul 2004
    40 something views and noone responds c'mon guys i need advice :waah:
  3. Morphine
    Morphine weeee!
    23 Feb 2002
    the clarity of the display is greatly reduced when using composite. red the bi tech article, or search around on www.mp3car.com forums for PSOne LCD mods and how to use the display as a VGA monitor.
  4. plazymburn
    11 Jul 2004
    if i go the vga route, does my graphics card need to have csync or is that just for composite, ive located all the parts i need for the vga mod and re-read everything i can find so now it seems quite simple. just confused about the csync thing. oh yeah on starfoxs site he says you need veroboard and a Ti74LS86AH IC (4 way TTL XOR gate) whats this for as i dont see these used anywhere, unless its for the hsync vsync mod for cards without csync, is that right. once again do you need csync if you do the vga mod.
  5. karrektor
    karrektor What's a Dremel?
    18 Jul 2004
    what cards work?
    I own a G4 Ti4600 to be honest im not sure what connectors im looking to hook the LCD upto or if this card will even do it anyone able to enlighten me ?
  6. plazymburn
    11 Jul 2004
    from what i read, cant remember where exactly as ive read so much about this mod :sigh: but the ti4600 doesnt support csync, which afaik is necessary to make this mod work you can make the vsync \ hsync to csync circuit but you need either a video card with two vga outs or a pci card. and a soldering iron,LM1881N Video Sync Separator,veroboard,wire,2 x 22uf 10v electrolitic resisitors,2 x 2.2kohm resistors,a 15 pin d shell,3 x 75 ohm resistors,and a vga cable, :rolleyes: where the heck do i get veroboard from :confused:
  7. Pash91
    Pash91 What's a Dremel?
    25 Jun 2004
    Get a Matrox Mystique from Ebay. I was supposed to get mine for 99c plus shipping until someone decided it would be fun if I wouldn't get it for that price. Only payed 20 plus shipping. Not bad.
  8. plazymburn
    11 Jul 2004
    won bid for matrox pci card on ebay cost me 12.50 :D now just hope it arrives and i dont get robbed, ive never used ebay. so hopefully all i need is a 15 pin d shell, some 75ohm resistors, and a vga cable.
  9. plazymburn
    11 Jul 2004
    heres another thing i found, sony have a parts centre, call them 08705 111999 - Open 8.30-6pm Monday to Friday, and ask to be connected to their parts supplier or that your trying to find a cable for a product then you can get av connection cable(SCPH-180e) which goes from 3.5 mil jack to 3.5 mil jack not sure what you could do with it tho, seems pointless now i thought about it but there ya go
  10. SanDmaN
    SanDmaN Minimodder
    11 Mar 2004
    A phono [video + 1 audio] > 3.5 jack [plugs straight into psone monitor @ back] is what you really want for composite - I got mine from a sony digi-cam - and it works a treat :]
    If you want sound then you would hack off the audio phono and add another 3.5 jack and plug in to your mobo speaker socket.
  11. plazymburn
    11 Jul 2004
    has anyone from the uk hacked up their psone screen apart and done the vga mod just wondered how it went
  12. plazymburn
    11 Jul 2004
    this is what i have so far
    psone screen
    vga cabe
    waiting on matrox mystique pci card off ebay
    15 pin d shell and 75 ohm resistors coming from maplins
    wire
    impatience
    this is all i need right
    im probably irritating you all with this mod that you've seen done a thousand times but im new and i like it and i will make it work
  13. SanDmaN
    SanDmaN Minimodder
    11 Mar 2004
    Well I have done all the wiring but cant seem to get the screen to display without distortion, this may be down to the graphics card [2mb matrox mistique].
    If I plug the monitor into my 9800pro via composite it works a treat - only problem is that I wanted 2 desktops not the same 1 twice.
    If any other UKers have got their screen working through powerstrip let me know your settings.
  14. plazymburn
    11 Jul 2004
    ok im getting somewhere, im just confused about powerstrip
    ive got it setup,agp graphics card and matrox mystique pci
    to get powerstrip to configue the psone screen i have to set the pci card as my primary in the bios however doing this my main monitor becomes the extension i've tried messing about with powerstrip but when i boot with my agp as primary i cant find the matrox card anywhere in powerstrip is this possible to do, where is it, what i mean is can powerstrip detect both of the graphics cards or just the one set as primary in the bios if not how do i set the correct settings in powerstrip cause the screen is garbled
  15. fishthecat
    fishthecat What's a Dremel?
    6 Mar 2002
    Yeh. I'm using a PAL sony lcd and a Matrox mistique.
    1) I couldn't get a VGA image without plugging a monitor into the card as well. I think I need that resistor trick to make windows think there's a monitor on the card. (Anyone got the URL?)
    2) Fiddling with powerstrip gave me a nice flicker free image, BUT it was really dark. Really really dark. So I'm back to using tv out from my main card for now.
    When using coposite/AV in, the image is VERY red. It's OK when I use my TV out as I can fiddle with colour correction, but with a camera/TV plugged into it it's far too red. Anyone got any ideas about how to make it less red?
  16. plazymburn
    11 Jul 2004
  17. MegaRouge
    MegaRouge What's a Dremel?
    9 Sep 2003
    I might not know what I'm taking about since I've only used TV out with my PSOne LCD, but on mine the brightness controls on the front can take it from very dim to insanely bright when I turn the brightness up. Wouldn't the brightness controls on the LCD itself correct that issue for you?
  18. fishthecat
    6 Mar 2002
    The brightness controls on my one do little. turning it up and down is enough to take the 'edge' off teh redness when using TV out, but doesn't give a readable image when using vga. I'll try re soldering with shorter wires and give it another go.
  19. plazymburn
    11 Jul 2004
    there was a redness "hack" posted somewhere on mp3carforums where you solder some kinda resistor on to the round pcb
