antec 900 case
Discussion in 'Hardware' started by nigelleg, 24 Mar 2008.
  1. nigelleg
    nigelleg What's a Dremel?
    4 Jan 2008
    I have been looking for a case for my new build
    Things I wanted from the case
    Fan in top/roof of case
    Plenty of options for additional fans
    Bottom mounted PSU
    Windowed side panel
    Ability to hide cables and wires
    This seems to meet most of my needs just not sure if its cable friendly but I can work with that
    http://www.antec.com/us/productDetails.php?ProdID=15900
    Please let me know of any better options
    Thanks
    Nigel
  2. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Cooler Master CM690 suits ALL of your needs. Just buy the windowed side panel. The Antec, meets all your requirements apart from the cable management, which, it sucks completely, and is one of the worst cases I have used for that.
  3. Jik
    Jik A Dremel, what is it?
    19 Dec 2007
    I have one of those Antec 900s for one of my computers. Its a great case for cooling, has lots of room, and looks good. The cable management in it is non existant, but there is an easy fix. Just get a little electrical tape and run the wires along the joints in the edge of the frame. The way they fold the metal in it leaves a little nook that you can hide wires in if you try.
  4. Guest-16
    Guest-16 Guest
    We went to i33 yesterday and there were tons and ton of 900s - so many I lost count. The best one I saw had white LED fans and silver bits inside - it looked completely pimp :D
    But like Lamboman said - the 690 is a good competitor :)
  5. nigelleg
    4 Jan 2008
    Thanks
    Dont know how I missed that case (690) it looks perfect I like the option of the 80mm fan blowing through onto MB from the back
    Its also half the price of the 900
    Only negative I cant find a windowed side panel in stock
    Cheers again
    Nigel
  6. Akava
    Akava Lurking...
    28 Jul 2007
    The 690 is an awesome case, cool (temps) as anything comes with 3 dam near silent 120mm fans and imo looks great, my only problem with it is that although the side window looks brilliant, its probably harder to get hold of than the Duorb. :dremel:
  7. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    the only problem with my antec 900 is that the connectors for the usb ports and the firewire had to run all the way from the top to the bottom and it was one very tight fit. also long video cards are a tight fit as well and the internal fan mount had to be removed. no big deal though, I cant see anyone needing to use that one. other than that, I love it.
