Hardware Antec P182 Performance One
Discussion in 'Article Discussion' started by Tim S, 26 Apr 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Guest-23315
    Guest-23315 Guest
    Still a nice looing case.
    DO you guys think you can get some photos of the P182 SE??
  3. DougEdey
    5 Jul 2005
    Much nicer the the other cases \o/
  4. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Still looks like a fridge but I like the gun metal paint.
    I have never been a fan of the case though, but like your review all the same.
    Can we ever expect to see a review of the Silverstone TJ09? I have it and have never been happier about a case, and I've owned CM and currently have the Stacker 830. Have also had multiple Lian Li's but nothing has come close to the TJ09. Its all a matter of personal preference but I think the world need's to see a Bit-Tech review ;)
  5. alextwo
    alextwo <a href="http://forums.bit-tech.net/showpost.php?p
    29 May 2003
    I've just realised that the P180 I ordered back in March, is in fact a P182! :)
    It's certainly a great case, if a little cramped.
  6. KillerCroc
    KillerCroc What's a Dremel?
    8 Oct 2006
    The case seems spacious enough, but I'm curious as to why you mounted your HDD's in the upper chamber rather than to lower - wouldn't that have impacted the airflow and temps in some way?
  7. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    The lower bay is definitely better for the HDDs. the top restricts the airflow to the motherboard, and can cause temps to rise.
  8. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    you wait zr_ox, I've got a crossflow for my stacker 830, that should do the job of the TJ09's duct for the gfx
  9. Krikkit
    21 Jan 2003
    That looks like a minor alteration to an otherwise fantastic case, ending up with another fantastic one with fewer niggles. If I wasn't in love with this Chieftech, I'd have it. Clean, simple and well designed.
  10. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    fixed :p
  11. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    It's still a mini-fridge. A touch easier to cable SLI setups now, but it's still a mini fridge. And still ugly.
  12. Mother-Goose
    22 Jul 2004
    Yup, no style what so ever.
  13. kempez
    kempez modding again!
    4 Aug 2005
    I hate the case tbh. Cable routing sucks, it's hard to work with and feels cramped (despite being quite large) and it's FUGLY
    Good review as usual tho
  14. Krikkit
    21 Jan 2003
    Is this more to your taste, sir?
  15. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    the advantage of the case having no style makes it blend in with a high end new sound system. it's not as easy to notice, but atleast it's prettier then the kandalf :p
  16. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    wow. I don't think i've seen something uglier by design in a looooong time.
  17. Jipa
    5 Feb 2004
    Nice review, but I can't help wondering how the hell could the WC tubes make any noises? :) TBH I think the rubber grommets are there to prevent the tube from scratching against metal and thus damaging itself. Tiny thing tho.
    Unfortunately there's not much new in the 182 as the review clearly shows, actually I think the wire management route behind the mobo-tray is the biggest. The paintwork is the second and that's it. So it indeed is an update instead of new model.
    Had I been in the team, I really would have got rid of the damn top-thingadilly! I hate it! It's the only ugly thing in the design, and also rather useless IMO. Maybe it helps if one has 8800GTX's or overclocked Prescot, but to me it seems just useless. I don't know if that's a common phenomena or not, but atleast in my case the top fan is also the one that's failing. I'm not too confident about the quality of the tri-cools, yeah they are relatively silent at slow speed, but simply too many of them start making noises after some use.
  18. Fod
    26 Aug 2004
    jipa: the radiators have fans attached to them. fans vibrate.
    and yeah it's an update, hence it being called the 182 and not the 280.
  19. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    I have to agree with Jipa on that one, since adding grommets to the tubing inlet/outlet is not to reduce vibration. To reduce vibration you need to decouple the offending device from the chassis which is not the purpose of said grommets. OK there may be a miniscule amount of vibes from the tubes, but they would be so low you would never notice them.
    I also agree that a case update should be referred to as 180b or whatever since they seem to be marketing it as a new case. It is clearly a revision and so should be branded accordingly.
    it's all just an opinion and none of us are right....well except me :hehe:
  20. Jipa
    5 Feb 2004
    Well you were extremely wrong in this one as P180B has been out for an year or so ;) I got your point, just had to nit-pick a bit.
Tags: Add Tags
