Networks Antennas help
Discussion in 'Hardware' started by MajestiX, 30 May 2010.
  1. MajestiX
    MajestiX What's a Dremel?
    14 Apr 2002
    Just wondering if 2.4Ghz antennas will work in the 5Ghz range
    and if G rated ones will work for wireless N
    looking to pick some high gain ones but just can't find any TNC ones with magnetic base so i can stick it somewhere higher
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    In theory they should, its just some shaped metal, a pringles tube works as one after all.
  3. marc.knuckle
    marc.knuckle What's a Dremel?
    19 May 2010
    true they should work but i am not sure it will work any better with n than g.
    also, my experience with high gain is that they dont really improve much at all but that may just be specific to my set up
  4. MajestiX
    14 Apr 2002
    is that to both questions
    as all antennas I see say 2.4ghz and never really 5ghz
  5. adam_bagpuss
    24 Apr 2009
  6. capnPedro
    11 Apr 2007
    An antenna's length depends on the wavelength of the signal it's tuned for. Wavelength = v/f, so although they will technically work, the signal reception will be absolutely terrible.
