Build Advice Any parts i can get while i wait?
Discussion in 'Hardware' started by dan-ere-07, 30 Dec 2010.
  1. dan-ere-07
    dan-ere-07 What's a Dremel?
    29 Mar 2007
    I'm going to be building a pc next month (waiting for sandy bridge) and i was wondering, is there any parts i can ger now before the VAT goes up?
    I was thinking HDD, 2 of these: Link
    SSD, Maybe this: Link
    Maybe memory? Link
  2. Edwards
    Edwards Minimodder
    8 Oct 2010
    Sandy Bridge (1155) uses Dual Channel memory, not triple.
    I wouldn't buy Memory unless you're certain you will be going sandy bridge. If you decide to get an i7-950, for example, because Sandy Bridge wasn't what you're expecting for whatever reason, you'll want triple channel memory, not dual.
  3. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    From experience I would say wait until you know what you want and buy it all at once.
    Some suppliers only give you 7 days to find any incompatibility issues with your build.
    I had a nightmare with Aria and ended up RMAing my PSU back to the manufacturer, which was a major pain in the butt.
  4. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    I wouldn't bother with an SSD, as 3rd gen Intels should be out in Q1.
    The F3 is a good choice, as is an F4 2TB if you have lots of media. I would look at a case and PSU personally.
    You could get memory, but even though it'll be compatible, I'd rather get that with a mobo and cpu. Which is just silly, but it's my way.
  5. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Case, PSU, Optical drives.
  6. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    The VAT rise is only £25 per £1000 spent so it's not going to be massive savings and hence not really worth the bother.
    A PSU and case and HD are all safe to buy now, and duel channel RAM if your sure your getting a sandy bridge.
    Graphics, it's likely that there be a price drop greater than the VAT rise in the next months with the release of the 560 in the mid range market.
    Any peripherals/windows you should get now.
  7. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    True, that's why I bought a 12K car this month. I didn't want the gubmint to get an extra 300 of my modding money! :thumb:
