Other Any way to distinguish between mobo and PSU failure?
Discussion in 'Tech Support' started by Zener Diode, 20 Mar 2018.
  1. Zener Diode
    Zener Diode User Title
    13 Sep 2009
    I've been having some problems with my PC lately. Sometimes when I try to boot, the fans spin up but it goes no further than that. Sometimes I have to power down and try multiple times before it boots. And I had one blue screen, and one instance where the PC just randomly powered down while I was using it. I was thinking that it could be either the mobo or the PSU (could be something else too I suppose. RAM maybe?).
    Is there any way to know without swapping out components? I'd rather not have to go swapping out the mobo because I'll need to get a new mobo, CPU, and RAM. Any advice is appreciated, thanks!
  2. TheMadDutchDude
    23 Aug 2013
    It would help if you mentioned what the parts were.
    Failure to boot is most likely motherboard related, I’d imagine. Try going down to a minimal setup with one stick of RAM and such, and see what it does.
  3. adidan
    25 Mar 2009
    Yeah tricky one. I started having random shuttoffs and the odd startup issue before my psu died.
    Unfortunately you can't say for sure until other parts are tried. You can start with what you have and try what the TheMDD suggests to start with.
  4. Zener Diode
    13 Sep 2009
    Thanks, I'll try running with 1 stick of RAM for a while as TheMDD suggested. I might take out the soundcard as well just in case. If it actually fails completely then I might have a better idea what's causing it, because it's easier to identify a dead PSU than an unstable one.
  5. TheMadDutchDude
    23 Aug 2013
    So what hardware is in the machine?
  6. Zener Diode
    13 Sep 2009
    Ancient tech haha
    CPU: i7 920
    Mobo: Asus P6t SE
    GPU: GTX 770
    PSU: Corsair HX 750
    RAM: 3 x 2GB
  7. TheMadDutchDude
    23 Aug 2013
    Yeah, I would wager it’s the board. :(
  8. Zener Diode
    13 Sep 2009
    Ah well, it's about time for an upgrade anyway! Thanks!
