Planning Anyone remember Wargames??
Discussion in 'Modding' started by Voluntary_Pariah, 17 Feb 2009.
  1. Voluntary_Pariah
    Voluntary_Pariah a Real Man™
    23 Jan 2009
    Well, if you don't, here is the Wiki link
    Anyhow, my plan to either mod or scratch build a case inspired by W.O.P.R (the evil computer, photos here).
    To do this, I'll need some help with a some of my ideas:
    1. The massive light pannels. I was thinking of creating the same effect using LED's, then wire it into the HDD (i think thats what it is) activity circuit, so that the pattern of lit LEDs changes. Only problem is, I have no idea on how to do this, or how to stop the LEDs from just flickering on and off.
    2. What is the practicality of water cooling the entire system, and then placing the rad(s), pumps and res(s) in the second layer? Do they need to be close to the tech they are cooling, or can there be a sizable distance from pump/res to heatsink?
    3. The rig is going to be for Gaming :)D), so what sort of size should the case be? I am planning to upgrade my exsisting set-up (actual hardware info to be added later), but I really could do with a rough guide.
    4. Got any advice for a total Noob? :geek:
    ta,
  2. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    The LEDS could be hooked up to a binary counter (There are a few CMOS chips out there) Just hook up a LED to each output, and connect the input to the hard drive activity output.
    This will make the LEDs flash in patterns when the drive is working. The problem with this solution is that when there is massive HDD activity it won't flash, as the LED output would be constantly on. This could be solved by hooking up a 555timer before the counter circuits.
  3. Fumduck
    Fumduck Have torch, will melt.
    5 Aug 2008
    Some hooked up to HDD activity. If you have multiple drives you can have an array per drive. You can also have an array representing CPU Utilization. You should be able to build arrays for anything that can be monitored. unfortunately, I'm nor enough of a programmer to give you anymore specific info, but I know there are plenty of them lurking the boards. ;)
    Don't forget to post a project log so we can see what you come up with. And maybe steal some ideas. :hehe:
  4. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    If you're going to be using it for gaming then it should be blinking with the network traffic. As for size, how big a guy are you? :)
  5. Voluntary_Pariah
    23 Jan 2009
    I'm just over 6 foot, but I don't want to make a full size model. it would be damn cool, but a little impractical as I am about to start uni, so it needs to be REASONABLY mobile. The actual construction will probably wait till I move in and can take advantage of a 5 axis CNC ;)
    As for the flasing lights, I have not idea how to wire anything to moniter something, so links would be welcome :)
  6. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    If you want the blinkenlights wall to actually show something useful, you could use it as a hardware visualiser for HD-tach or similar (though you might be hard pressed to find enough useful data points). An easier way would be simply to hook the HDD LED lead up to a microcontroller, and have each pulse from the LED line set up a new random pattern in the Blinkenlights. The lights themselves would be meaningless in their pattern, but the frequency at which the pattern changes would at least correspond roughly to HDD activity.
  7. Voluntary_Pariah
    23 Jan 2009
    could you send me a link to a guide on setting this thing up?
    thanks
  8. quietguy
    quietguy D'orc
    4 Oct 2007
  9. Voluntary_Pariah
    23 Jan 2009
    Sort of, but I was hoping for something a little more random. And simple to build. I might just wire up the LEDs in groups of ten, then use a decade counter (I've been doing some reseach, can you tell? ;) ) to change the lit pattern
    Any pointers in his area would be welcome
  10. quietguy
    quietguy D'orc
    4 Oct 2007
  11. Voluntary_Pariah
    23 Jan 2009
    yup. That second on looks perfect. Now I just need to try and work out the voltages needed to power about 100 LED's :S
    Although, I have had a thought. I could split the LED bank into both HDD and network activity. Of course, I'll need to do alot more reasearch before I actually put dremal to materials :D
  12. Fumduck
    5 Aug 2008
    I was thinking you could use something like this to controll the LEDs thru a USB port. You would have to create an application that montiors different system activities, and sets the LED states accordingly.
    I also found Phidgets, which look vastly more interesting. And it have a lot of device / interface options to really make something cool. :)
    Could be fun. Will be challenging. :)
  13. Voluntary_Pariah
    23 Jan 2009
    however, my programming skills are even less then my electronics skills (which I Haven't used since nearly failing my electronics GCSE)
    A quick update. I'm going to attempt to upload my first EVER SU model at some point tonight (UK time).
  14. Cheapskate
    13 May 2007
    Look up Vilkkuvalot II on Metku. In the forums they discuss adding LEDs and how to do it. It also updates that circuit with a circuit isolator and a way to add ultrabright LEDs.
    I should have the link somewhere in my 'toad log...
  15. Voluntary_Pariah
    23 Jan 2009
    Sweet! Cheapskate is looking at my stuff :D
    What a start! I feel blessed by greatness
    Ok. On to business: My current rig is the following
    Packard Bell BV Cuba MS-7301
    1x Intel(R) Pentium(R) D CPU 3.00Ghz (Duel Core)
    VIA Technologies Inc Standard Bridge Host
    NVIDIA GeForce SE/7200GS
    Two HDD (1 150Gb and 1 30Gb, both ATA)
    2Gb ram
    Any upgrade advice? My plan is to add a MINIMUM of 2Tb memory (I like films and music :D)
    SU model to follow
  16. Voluntary_Pariah
    23 Jan 2009
    We Now Have Pic's :D
    This is my first EVER SU model, so play nice with comments please :)
    The Red area on the back will have all the cables and input sockets there (hopefully), whereas the white area will have the LED bank
    A photo without the texture, just to give a better idea
    and finally:
    This shows the slots cut for cables and (possibly) Water cooling tubes to go through, and access the base area
    Well, what do you think?? :blush:
  17. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    I don't remember that movie at all!....
    [​IMG] :D
    Good luck with the build!
  18. Sir Digby
    Sir Digby The Supprising Adventures
    18 Jan 2009
    Ok, you HAVE to set the lights up so you can play noughts and crosses on them :hehe:
  19. wolfticket
    19 Apr 2008
    Now that would make a cool PC :)
    If I was you I'd go for pretty much an exact replica, but on a smaller scale. It looks pretty ideal to fit hardware in, and the shape of the thing isn't that complex (it is a prop after all).
    As long as you only use it to play Global Thermonuclear War and Tic-Tac-Toe :thumb:
  20. Cheapskate
    13 May 2007
    Is it me, or is it shaped roughly like a train engine?
