AS the title says, have you recently upgraed your GPU and now find yourself in the horrible situation where you have a 560 / 580 thats surpus to requirements. It's never nice being in this position, however I feel that I could certainly help you out of a tight spot.
Sorry i was actually hopeing to find someong that has just upgraded from a 560/580 to one of the brand new 7970's and therefore might be looking to get rid of their old one!
Seglespaan, I don't know if you are aware bit-tech has a marketplace for things like this. Although you do need to make a certain amount of posts to access it (I believe it is 75?). Hang in there and you'll be able to have a look
I did the reverse, I downgraded a GPU from an HIS Radeon 5850 (1GB, DDR5) to a lesser GPU as I did not need the HIS 5850 performance. I think that according to "tomshardware" the Radeon 5850 is classed as the same level of card as a GTX 560, or rather, thats what their Dec-11 table shows? Itchy
Benji, thanks for that i knew there was a marketplace somewhere but couldn't find it. Guess I'll just need to do some more poting then! Itchy, What happened toy your old card?
It's back in the original box with CD, manual, cables ready to go onto eBay. I have found that they bring bigger money on eBay especially if you can do a sneakey "private" with no fees.
Yes the marketplace is off limits to users with fewer than 75 posts, and trading with such users is strongly discouraged. @OP if you're looking for a 560Ti your best bet at the moment is ebay.
