Windows Anyone using AVG having trouble updating?
Discussion in 'Software' started by Deviate, 8 Mar 2004.
  1. Trickle
    Trickle What's a Dremel?
    14 Dec 2003
    There is an ftp address available aswell, so you could change the above text to look like this:
    [SERVER_NAME]
    1=free.grisoft.cz
    2=ftp.grisoft.com
    3=www.grisoft.com
    [SERVER_URL]
    1=http://free.grisoft.cz/softw/60/fe
    2=ftp.grisoft.com/pub/softw/60/fe/
    3=http://www.grisoft.com/softw/60/fe/
    Actual URL=3
  2. oshta
    oshta Guest
    but using AVG free i can only use free.grisoft.cz right???
  3. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    I have had those probelsm as well. I found a way around it by using the manual update. Just go to their site. For AVG free goto, Download ->updates.
    Then, on the left, click on updates AVG 6.
    Then, in the list, select AVG Antivirus free edition. Then click on select.
    Then download the correct file on that page. Read the instructions to see which file you need.
  4. Krikkit
    21 Jan 2003
    That's a problem for people like me who, unfortunately enough, can't manage to download a file in a web browser from them :( :sigh:
  5. tkwsn
    tkwsn What's a Dremel?
    27 Aug 2003
    Yes. I work at an ISP and that's what we recommend. It doesn't screw up your computer as much and detects virii much better.
    moorecomp - thank you very much -- I've been having some problems.
  6. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    Nope. I'm using AVG free version and this fix has worked for me. Thanks again moorecomp! :rock:
  7. oshta
    oshta Guest
    - But how do you set which server you what to use, mine just a has a dropdown, which only has free.grisoft.cz in it, how do you ADD a server location??
  8. richtea78
    richtea78 Guest
    If you read the thread you have to change the ini file - Moorecomp tells you how to do it. I managed it and Im a complete technotard :duh:
    thankyou Moorecomp for the helpful advice - its been annoying me for ages
  9. djrusty
    djrusty What's a Dremel?
    20 Aug 2003
    Thanks Moorecomp - fixed the problem for me - ncie one fella!
    :thumb: :thumb: :thumb:
  10. oshta
    oshta Guest
    DAM :wallbash:, sorry, im full-o-cold, and i cant think stright at all so i havent been reading thread right, sorry again, and THANKS to MOORECOMP
  11. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    I must say tahnk you to moorecomp for posting that fix for AVG. On some machines, doing it the way I posted did not work. Today, at work I tried his way on a machine, and it worked like a charm.
    Thank you. If you don't mind, we will put this up on our website for our customers.
    Thanks again :thumb:
  12. richman
    richman What's a Dremel?
    17 Sep 2003
    Nice One Boss :rock:
    Works A Treak Does That. Welcome To Bit - Tech
    Richman
  13. El_JimBob
    El_JimBob Minimodder
    28 Dec 2003
    Id had these probs recently and found that upgrading to the latest version worked ok for me (plus i hadnt noticed this thread yet, oops :)).
  14. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    I just installed a new copy of AVG free, they movced the "built in" update time 25 mins earlier to avoid traffic bottlenecks.
