Storage Anything wrong with this SSD?
Discussion in 'Hardware' started by russ555, 28 Jan 2012.
  1. russ555
    russ555 What's a Dremel?
    24 Apr 2009
  2. jamesn
    jamesn What's a Dremel?
    15 Jan 2012
    i just installed one of these into my new build. from a purely superficial view, it is fantastic. windows loads in about 4 seconds!
  3. murraynt
    murraynt Modder
    6 Jun 2009
    Nothing wrong with that ssd at all.
    But crucial have a deal on the m4 atm.
    I pull this froma nother thread
    Found via HotUKDeals
    'Crucial M4 from the crucial website available for £127.76 when using code naughty7 (7% off)
    Linky
    If you use cashback websites as well you can 15% using TopCashBack to make the price £111.76.
    Bargain!
    For info the cashback deal runs out in 4 days, dont know how long the Crucial code lasts.
    Been umming and ahhing over this SSD for a while. Think I might finally be tempted especially as I got a bonus this month
    Just gotta double check the storage space at home first.
    EDIT: It also looks like the code works across the whole range (64GB to 256GB)'
    I know SSD's use a lot less power than a hardrive but I don't know how much less. Sorry.
  4. russ555
    24 Apr 2009
    That's enough info anyway thanks :)
    EDIT: Nevermind the edit I derped xD
  5. murraynt
    murraynt Modder
    6 Jun 2009
    Yeah it's in pounds mate.
    You will need to buy from the crucial site to get the discount though.
  6. russ555
    24 Apr 2009
    Now the question is, is there any reason to go for one over the other?
    About the price of it I forgot to enter the code, once I did that the price matched what you said :)
  7. murraynt
    murraynt Modder
    6 Jun 2009
    Well I actually had the agility and it developed a flaw so I changed it for the M4. I couldn't be happier (Well Another 60gb wouldn't do any harm)
    Even though the the agility says it should do Read 525MB/s, Write 500MB/s it doesn't come near it according to Bit-tech
    http://www.bit-tech.net/hardware/storage/2011/08/17/ocz-agility-3-240gb-review/1
    The m4 seems to be the all round winner especially when you go over 64 gb.
  8. russ555
    24 Apr 2009
    Going to go with the M4.
    Is there a cash back site you would recommend as I have never used one.
  9. murraynt
    murraynt Modder
    6 Jun 2009
    Either have i :( Amm. Maybe somebody else can help on that? :rock:
  10. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
  11. russ555
    24 Apr 2009
    sparkyboy22 likes this.
  12. dBass
    dBass What's a Dremel?
    29 Jan 2012
    From what I've read most people prefer the Crucial because of the reliability and customer service. When looking at SSD's the M4 was recommended more often than any other drive, especially by people who had had problems with other SSD's and decided to switch.
  13. sparkyboy22
    3 May 2010
    Appreciated. Dont forget about checking there before you buy anything alse. I earnt £340 through it last year!
  14. Cutter
    Cutter What's a Dremel?
    14 Jan 2012
    Quidco and Topcashback both have deals with Crucial, but the Quidco one seems to suggest that its either or - i.e. you can either get 7% off with the code, or the 15% cashback, but not both. Topcashback is silent on this point.
    Anyone know the definite answer here?
  15. GeorgeK
    18 Sep 2010
    I've used this today - got 7% off a 64GB model and then 15% cashback as well - on quidco. You 'only' get the 15% cashback on the price excluding VAT after the discount (still around £9 back on a £71 drive) - it's tracked on quidco too so definitely works (will take some time for the cashback to be payable but that's the same with all transactions on all sites)
    EDIT: Also, the 15% cashback runs out tomorrow evening as mentioned above - not sure about the 7% crucial code however
  16. Jackg
    Jackg What's a Dremel?
    7 Jul 2011
    I have just ordered using that code as well!
    Waiting for my nice new M4 now.
  17. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    I would avoid crucial drives completely, based on the 5000 hour bug which is resolved in firmware 0309 and effects all drive firmwares below. However this firmware also intrduces another bug which causes problems in RAID arrays i.e random drive dropouts. Once your M4 hits 5000 hours your machine will either BSOD or randomly re-boot within 1 hour. This has caused a massive headache for me as i now have to trawl through 8 months of invoices and track down all the M4's i sold (250+). Crucial support are useless and i already have a stack of 11 512gig drives on my desk that are of no use until thae next firmware update is released in a couple of weeks.
  18. Cutter
    14 Jan 2012
    Thanks for the heads up Pookie. I'm not using a RAID array so the 0309 firmware should be fine for me until the next one comes out. Crucial's UK office is close to me so any issues with phone support and I can turn up in person at their door! :D
    Following up my earlier post, the voucher code for the 7% off worked and the cashback is now also tracked through Topcashback.
  19. feathers
    feathers Minimodder
    11 Apr 2009
    I don't like the green and black logo.
    Also I avoid anything with OCZ printed on it now.
    I looked at getting one of those last year but I read so many issues from people having BSODS and poor performance I went for Kingston instead.
  20. feathers
    feathers Minimodder
    11 Apr 2009
    Oh dear.
    Problem is that this forum is one that tends to have the little sheep mentality. Someone says something is good and then everyone on the forum says it's good. Crucial M4 is the thing everyone on the forum is buying because everyone else is saying it's good.
    Names to avoid in SSD:
    OCZ
    Corsair
    Crucial
