AOpen XC Cube EU965
Discussion in 'Article Discussion' started by Tim S, 14 Feb 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Looks like they're parallel to the front of the case in the motherboard picture...?
  3. Tim S
    Tim S OG
    8 Nov 2001
    Fixed - Rich meant perpendicular to the case sides and I didn't pick up on it. Thanks. :blush:
  4. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    shame there is a lack of good SFF, I adore my SN45g even though it's getting on abit now. Makes a very good server and the PSU in it is pretty increadable for something rated at only 200w.
    I think shuttle should come out with a mini server with the SN45g chassises and a more modern C2d mobo and hard disks mounted horizontaly accross the front, that way it could easily hold 5 or 6 disks in a very small area (mounting a zalman ulta thin fan undernath them for optimum cooling) can you imagiain a shuttle with 6TB of hard disk space... drool. They should also make part of the hard drivce cage removable so that a graphics card can be installed and add a flap on the left hand cover so duel slot cards can be installed (and make it look like your shuttle has a super charger)....
    dammm If only I had a grand I would do it myself to one of the more modern shuttles (if they still make the smaller ones with a PCI-E slot.)
  5. Guest-16
    Guest-16 Guest
    Tbh, if they made a server with G2 or G5 chassis that would be faaar nicer looking.
    Shuttle should really make stuff to order: Choose what chassis you want, choose what board you want in it and then they make it.
  6. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    It seems odd to abandon PCI yet include a parallel port. It's not a bad attempt but, as stated in the article, needs a little revision. (Why so many useless internal USB ports? - in a SSF case 2 should suffice.)
Tags: Add Tags
