CPU Apparently the I3 6100 overclocks..
Discussion in 'Hardware' started by Vault-Tec, 12 Dec 2015.
  1. Vault-Tec
    30 Aug 2015
  2. rollo
    rollo Modder
    16 May 2008
    They would not of posted it overwise. Intel have done AMD A favour over a years in not allowing Overclocking on the lower end chips. Not been good for consumers though.
  3. TheMadDutchDude
    23 Aug 2013
    Yep, full overclocking capabilities have returned, thanks to a few clever guys.
    I can't wait to unleash my 6320 under LN2 in the new year. :D
  4. Guest-16
    Guest-16 Guest
    *Conspiracy Klaxon*
    PC sales are bad and Intel/partners need a boost, so this was 'accidentally' allowed. This happened previously with H87/H81 and Intel slammed the door immediately with high level calls by important people threatening all sorts of business/relationship repercussions.
  5. javaman
    javaman May irritate Eyes
    10 May 2009
    Will this require a Z chipset motherboard or will it be open to H or B chipsets as well. The way I'm reading it Z will be required for changing multiplier still but this is done by changing clock settings?
  6. Guest-16
    Guest-16 Guest
    We'll see as the BIOS' and more details roll out.
  7. TheMadDutchDude
    23 Aug 2013
    Multiplier options are sometimes available on lower end chipsets, going down and up, but once you unlock the ability to change the BCLK with a beta BIOS, the ability to change the multi disappears. That's how it is, at least for now.
  8. mrbungle
    20 Sep 2004
    Nice!
    Goes off to price up a poverty Skylake build.
  9. Spigsy
    Spigsy What's a Dremel?
    28 Sep 2009
    Would I be right in thinking that as long as I have the right chipset, an i5 6400 would be just as good a bet as the i5 6600k?
  10. mrbungle
    20 Sep 2004
    Kinda.
    Its limited to bclk speed of the board rather than the unlimited multi.
  11. TheMadDutchDude
    23 Aug 2013
    Well, we've seen >150 BCLK hit on various boards so far. The only thing that will be different is that you'd have to play with the RAM dividers a little more to get your RAM speeds to work properly. :)
