News Apple announces new APFS file system for macOS, iOS, and more
Discussion in 'Article Discussion' started by Gareth Halfacree, 14 Jun 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Isn't the latest OS X version 10.11 El Capitan?
  3. Gareth Halfacree
    4 Dec 2007
    You're right: Yosemite is 10.10. Got me codenames mixed up there - I'll go fix it, ta!
    EDIT: No, t'was Apple wot got its codenames mixed up. The developer documentation clearly says 'OS X 10.11 Yosemite' in it. Exonerated! (But I'll still go fix, 'cos it's a mistake regardless of who is responsible.)
  4. Flibblebot
    19 Apr 2005
    ...and you'd think that Apple would know their own OS names! :sigh:
  5. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    Yeah no kidding... and yet they made fun of Vista for being confusing :duh:
    Anyway I'm not really against the idea of APFS being only supported on 10.11 or newer. Seems to me that Apple wants to get rid of their old Core2 users (but is struggling to do so), and this filesystem gets them very slightly closer to doing that. I don't really care either way - MacOS is becoming less and less interesting every year since Lion.
  6. Elledan
    Elledan What's a Dremel?
    4 Feb 2009
    Yes, but will it be case-sensitive? :D
    Compared to NTFS, ZFS and Ext4, Apple is truly playing catch-up at this point. Took them bloody long enough.
  7. RedFlames
    23 Apr 2009
    This is a company that insisted everyone call the 3rd gen iPad 'The New iPad', even after the 4th gen launched...
  8. schmidtbag
    30 Jul 2010
    Uh... if anything needs to catch up, that would be NTFS. NTFS still requires to be defragmented, there are a good chunk of special characters that can't be used in filenames, it overall isn't as fast as alternative filesystems, it doesn't use checksums, it doesn't offer snapshots, I'm not aware if it supports journaling, and so on. Maybe some of that isn't true anymore and I just haven't been aware. Since they keep using the same name for over a decade, it's hard to keep track of what OS supports which features.
  9. Elledan
    4 Feb 2009
    Defragmentation I'll give you. But NTFS offers volume shadow copy (copy-on-write), has always offered journaling, encryption, compression, etc.: https://en.wikipedia.org/wiki/NTFS
    Many of the limitations assigned to NTFS are often limitations of Windows, such as case-sensitivity. This becomes clear when new subsystems (like the new Linux subsystem in Win10) do not have such limitations.
    Of course, ZFS is far ahead of NTFS and Ext4, with self-healing capabilities and everything. It's what I use for my *BSD systems when possible, because it only makes sense.
  10. schmidtbag
    30 Jul 2010
    The shadow copy, to my knowledge, needs to be explicitly specified per-file. Other filesystems such as btrfs just do it automatically using un-allocated disk space (without actually taking up disk space). Seems I was mistaken about journaling, but I wasn't too sure if I was right about that anyway.
    NTFS to my knowledge has always supported encryption, which is great. But... the compatibility of that encryption breaks between different versions of Windows. That is really inconvenient to, for example, encrypt a file using Windows 7 on an external HDD, and then try to de-crypt it on an XP machine.
    Compression is one of the only significant advantages of NTFS. Though, it hasn't always been perfect. I've had corruption issues thanks to NTFS compression in the past, though it is rare and I still use it.
    Agreed, though I think btrfs will soon surpass ZFS. However, ZFS is a much more practical "general purpose" filesystem; btrfs is a bit too complex (and therefore slow) for the average user.
    Another thing I forgot to mention - symlinks and hardlinks. I'm well aware Windows supports them now, but I don't think all versions of NTFS supports it, there is no user-friendly way to work with them, and there are limitations to links on NTFS. Symlinks are one of my favorite filesystem tools, and Windows makes it such a burden.
  11. Elledan
    4 Feb 2009
    To be honest, I only use NTFS compression (since I started with Win2k), never bothering with shadow volume copies or encryption. Coming from FAT32 NTFS was a very nice jump ahead :)
    ZFS is pretty much at the point where one could begin to call it 'mature', I guess. btrfs is still in the 'could nuke your data if it has an off-day' stage, last I read up on it :) I use ZFS with my FreeNAS-based fileserver at any rate.
    No disagreement there. I regularly work with BSDs, Linuxes and similar, and it's so nice to just 'ln -s' (or equivalent) glue a file or folder structure together. Maybe that the new Linux subsystem will improve matters there, though. NTFS is quite capable, it's always been Windows holding it back.
