SketchUp Apple G5 led clock
Discussion in 'Modding' started by kaujazz, 14 Apr 2009.
  1. kaujazz
    kaujazz What's a Dremel?
    22 Feb 2009
    i have been researching on G5s an i found this.
    Can someone tell me how to resize it so all stuff will fit
    Or to get these pics in to EAGLE?
    I think you can see the difference between the clock PCB pic and real one
    On the diagram the clock PCB is bigger then the led PCB !
  2. jrs77
    jrs77 Modder
    17 Feb 2006
    First you need to look at the easiest part used on the PCB to get measurements for. In this case it's the SC8560 digital clock IC. It's 25,6 mm x 10 mm. You can look it up here.
    If you got that, you can go on and resize the image to match the size of it.
    Next you need some fix-points, to matchup the two different sized PCBs. Therefore we take the 3 holes that are used to fix the two PCBs to each other (marked red in the drawing!)
    And voilá, you got your measurements for the PCBs.
    I didn't measure it 100%, its just a very quick and dirty thing I did in Photoshop there, but the way to get it done should be clear.
    kaujazz likes this.
  3. kaujazz
    22 Feb 2009
    Thanks jrs77!!!
    :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb:
    I've got another question
    How do you do a mirror reflection?
    I want to use toner transfer to make those PCBs.
    jhanlon303 likes this.
  4. jhanlon303
    7 Sep 2006
    Thank you for finding this. For the last elebenty years I have been working on my G5 cube. This circuit fits well with the cubes design goal of clock radio and wake me upper.
    john
    +rep for the find
    PS to eveyone:
    Yes I still have it and no it's not done.
  5. drleipzig
    drleipzig What's a Dremel?
    27 Oct 2010
    Where are the parts list of this?
  6. jrs77
    jrs77 Modder
    17 Feb 2006
    It's a kit you can purchase. Link in the first post.
    If you look at the pictures you'll figure out the parts used tho.
  7. YolandoSewester
    YolandoSewester What's a Dremel?
    12 Apr 2012
    :clap:so,i think you are a kindful!
