Windows application restarter?
Discussion in 'Software' started by herbs, 14 Jul 2009.
  1. herbs
    herbs Nobody but us chickens
    7 May 2001
    Hi,
    Does anyone know of a free application monitor that will restart an application if its not running after a certain amount of time. I have found 3 and none of them work quite how I need it to.
    Application monitor (jockersoft) works well but is on the screen all the time, and minimised is not good enough.
    Keep running(JP electronic.com) is no good as it blanks out the page.
    Autorestart (dont know the supplier) doesnt work at all for my machine.
    So any alternatives would be welcomed, I cant use autoit.
    This on windows.
  2. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    I'm not sure about software, but do you know if the application runs as a service? (I'm doing this under XP fyi.)
    If so, go to run > services.msc
    Find the process in the list and right click > properties
    You have a few options on the Recovery tab. For first, second and subsequent failures you can either restart the service or run a program. Most application restarter software just makes changes here.
  3. herbs
    7 May 2001
    It's not a service, and I cant run it as a service.
  4. Silver51
    24 Jul 2006
  5. herbs
    7 May 2001
    Thanks for the info but these are dont fit the requirements.
  6. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Task Scheduler? That has the options to restart the task if it stops, and you can even set a lot more options. Check it out.
    Also, knowing exactly what you want to accomplish would help us to help you. :)
