Cooling Appliing tim with Titan Fenrir
Discussion in 'Hardware' started by frojoe, 24 Jun 2010.
  1. frojoe
    frojoe What's a Dremel?
    17 Dec 2008
    I was wondering if it is better to use more tim with a direct contact cooler like the Titan Fenrir to attempt to fill the voids between the heatpipes and base of the coolor, or use the normal, very small amount of tim.
    Thanks.
    -Joe-
  2. capnPedro
    11 Apr 2007
    Arctic Silver recommend "tinting" the surface of the the cooler by working TIM into the edges of the heatpipes with a credit card, then scraping excess off before mounting with the normal small grain of rice size amount.
  3. frojoe
    17 Dec 2008
    Sounds like it could be the best of both, thanks.
  4. Action_Parsnip
    Action_Parsnip What's a Dremel?
    3 Apr 2009
    I got a fenrir and i literally slapped on it. Good squidge down either side of the heat pipes, then a slightly larger than normal blob on the cpu. Dont know my exact stress testing temps but theyre pretty darn good for a q6700 with 1.4275 volts through it running Linpack for 4 hours and it absolutely DESTROYS my old zalman 9500. Hardocp's review of the titan was really bad due to contact issues, so i pre-empted those by liberally applying thermal paste. Sweet cooler and an excellent choice you made buying it.
  5. tristanperry
    tristanperry Minimodder
    22 May 2010
    I did roughly the same. Sounds like I applied a bit less TIM, but with the same result.
    I applied a (thin) strip to the ridges/grooves on the heat pipe base, then the size of a small pea to the CPU.
    All 4 CPU cores are in the 30s at normal/low use (with CPU fan RPM in the 900s), and in the 40s under load (with 1,200-odd RPM). So am pretty happy with its performance.
  6. Telltale Boy
    Telltale Boy Designated CPC Jetwhore
    3 May 2010
    I found it very hard to get an even spread on the CPU usign the titan fenrir's TIM. I tried using the pea-sized blob and credit card technique but it seemed too putty-like. In the end I just put on a fairly large amount & just applied it by putting the Fenrir on top & moving it around a bit.
    Got fairly good temps though: around 30°C at idle & 50°C at load (Intel Core i3 530 @ 4.2GHz 1.3V).
