Arcade Cabinet
Discussion in 'Project Logs' started by Bursar, 15 Mar 2003.
  1. Bursar
    Bursar What's a Dremel?
    6 May 2001
    Figured I should put this in here rather than hog Arcanums thread :)
    Anyway, I've had some free time over the past couple of days so have started bolthing my cab together.
    Not too many pics, as constrcution is a bit dull.
    But here's one of the frame completed, and with my temporary control panel placed on top:
    http://www.philspcmods.com/images/arcade/framecp.jpg
    The base is on wheels so I can easily move it around, and the little frame work inside the base will hold the PC steady. I'm going to be stripping the PC down and upgrading parts of it in the not to distant future, so I might bolt it to the base as wellto make it super-steady.
    Tomorrow I'll be fitting some more of the external panels and the monitor shelf.
    More pics as I take them :)
  2. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    So you're gonna be running a system in there just to play games with a friend or something? :eyebrow:
    It's a cool idea, but I think you have a luxury problem ;)
  3. Bursar
    6 May 2001
    Yeah, there's gonna be a P4 system in there running emulators for arcade games. The control panel that's in the pic has 2 player sticks and buttons, but the final one will have enough for 4 players.
    Luxury problem? I wish :) The MDF is cheap enough, and the PC can be used for other things too.
  4. Arcana
    Arcana What's a Dremel?
    25 Jan 2003
    Not too shabby...hurry up and get some more pics for us...
    What kind of hole saws do you use for the MDF? spade bits or circle saw bits? Just curious.
  5. Green Soda
    Green Soda What's a Dremel?
    26 Dec 2002
    Great chance to build a file server inside it so when your not Pacman-ing (if you dont put Pacman on there you will die a slow death!!! Jk Jk!! :p), you can use the p4 for something.
    Are you going to put a nice vid card in there since you will only be doing emulator style games, or are you going to make it better and put a nice card for UT 2k3?:clap:
    Also, flat pannel or crt?? im assuming you'll prob use an old monitor, but thats just my guess...
  6. the_secret
    the_secret What's a Dremel?
    29 Sep 2002
    ->or are you going to use a TV? :)
  7. Bursar
    6 May 2001
    I did buy a set of spade bits, but when I made the prototype control panel (from chipboard), it went blunt fairly quickly, so I bought a holesaw to make holes in the MDF. worked a treat.
    Currently the machine has a GF2 Ultra in it, but I should be getting that upped to a GF4 4800SE in the not too distant future.
    The screen is going to be an Iiyama 17" monitor.
    Dunno how well FPS games will play on it to be honest. I'm quite used to the keyboard and mouse combo. I guess a stick and trackball would work quite well, but I'd need a third hand to press the buttons :D
  8. Stew
    Stew Disgruntled Postal Worker
    6 Mar 2002
    hey man really good luck with it, A friend and I started building a Mame cabinet but due to unemployment it only got so far.. :sigh:
    The specs you intend to use seem to be way high for what for an arcade machine would need, and I would reccomend that you use a large 4:3 tv for the screen, has the best arcade feel/picture quality ratio.
    A Pc monitor might be a bit too "clean looking"
    Should be quite cheap for a 20" tv too :)
    I wouldn't have thought FPS games would play great with those controls though, but personally I don't think theres much point in building one of these things to play UT2K3.
    Anyhoo good luck with it :clap:
  9. Bursar
    6 May 2001
    A TV would be a good option to mount in the cab, but funds are limited, and I have the 17" monitor sitting spare at the mo.
    I know the specs are high, but some games such as Metal Slug really slowed down on an Athlon 1.2@1.33 with the GF2U card, so I figured I'd get a decent spec so it would cope a bit better.
    Also means I get a little bit of future proofing as newer games are added.
  10. Stew
    6 Mar 2002
    oh yeah well, if you've allready got the monitor lying around then use it! :hehe:
  11. Green Soda
    26 Dec 2002
    I was half kidding about the UT thing. I wouldn't want to play UT standing up, but i guess it could be done.
    Anyway: Are you going to build it into a fileserver as well?
    BTW: Im not sure you would want to do this, but turn the res down really low, then it would look more like a TV...
  12. Stew
    6 Mar 2002
    no he wouldn't need to.
    All he needs to do is enable scanlines in Mame.
  13. Arcana
    25 Jan 2003
    Yer scarin me with that Metal Slug comment...
    I'm plannin on an Epia-800 for my arcade console...and Metal Slug is one of my favorites...is that a bad idea then? should I plan for larger???
  14. Bursar
    6 May 2001
    Well, when there's two players, a load of baddies, and bullets flying everywhere, you will need something fairly hefty to keep it moving at a reasonable speed.
    If you're only going to be playing single player, you may not run into these problems.
    As always, YMMV.
  15. dez
    dez What's a Dremel?
    16 Jul 2002
    ive got a link at home the most killer mame arcade cabient ive ever seen. im at school now, ill post later :)
    /note to self, post later
    dez
  16. Arcana
    25 Jan 2003
    The most killer arcade cabinet ever is one that you build for yourself, no matter how it compares to other greater cabinets...at least thats my belief :D
    My parts come in today...pics tonight...I'm also going MDF shopping.
    So Bursar....wheres the pics at bro? show us more!!!
  17. Bursar
    6 May 2001
    I knocked up a couple of webpages showing my progress so far.
    Not too much progress yesterday. Starting mounting the panels and fitted a hinged door so I could the PC. Also fitted the monitor shelf.
    Still plenty more to do :(
  18. daydreamingknight
    daydreamingknight What's a Dremel?
    9 Jun 2002
    Wow, it's looking really good!! Looking forward to seeing more progress!
    DDK
  19. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    What's with the sad face, Bursar? That's the face I get when I actually finish something...
    Looks cool, though, but isn't the computer a little unnecessary powerful for these old games?
  20. Arcana
    25 Jan 2003
    I noticed you used chipboard also...for the prototype...not being a wood genius...I'm assuming the MDF that I was considering is not as weak at the edges as chipboard? I intend to seal and paint the console when I'm done building...will that prove sufficient in waterproofing and strengthening or is there somethign I shoudl know?
