Modding Arctic Rain by InitialDriveGTR
Discussion in 'Article Discussion' started by brumgrunt, 25 Sep 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. PlayedStation
    PlayedStation Possessed like an apostrophe
    21 Oct 2010
    Nice bong.
    Sorry, I couldnt resist.
    That is seriously bad ass.
  3. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    That's interesting. I reaaally shouldn't read projects like this they make me want to go build one.
  4. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    That's an excellent build. My hat's off to you.
  5. ya93sin
    ya93sin What's a Dremel?
    18 Oct 2011
    Beautiful
  6. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    So what are the temp reductions when using this way of cooling.
  7. Bakes
    Bakes What's a Dremel?
    4 Jun 2010
    The explanation of bong cooling as evaporating the hot water whilst leaving the cold is disingenuous. The fan does evaporate the water - but this requires energy to overcome the intermolecular bonds, which is absorbed from the surrounding water, known as latent heat. This latent heat requirement is massive for water - the amount of energy to heat 1g of water by 1C is about 4.2J, but the amount of energy required to evaporate the same amount of water is 2260J. This is why only evaporating a small amount of water can result in a massive reduction in temperature - it's far more efficient than simply relying on a heat transfer process like a radiator.
    Obiwan - the temp reductions can be considerable. Basically, if you try hard enough, you can get your water at a sub-ambient temperature, which is obviously extremely useful for efficient cooling.
  8. InitialDriveGTR
    InitialDriveGTR What's a Dremel?
    13 Jan 2012
    Thanks everyone! As for temps, check out the build log!
Tags: Add Tags
