Asking for help choosing an external HDD
Discussion in 'Hardware' started by dragontail, 17 Aug 2007.
  1. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    Hey guys, I'm looking for an external HDD. I not sure if its best to buy:
    a) A complete external HDD, like the WD MyBook 500GB
    b) An internal drive and an external cover, like the Samsung SpinpointT 500GB + IcyBox
    It would be desirable if the drive had power saving features, so it won't die very quickly. Gimme a shout if you've owned an external HDD, or can recommend me any. Any advice is greatly appreciated.
  2. n0d4x
    n0d4x What's a Dremel?
    1 Feb 2007
    internal seagate in a external case is always a good option
    good cheap 5 year warranty on the hardrive from seagate
  3. fatty
    fatty Minimodder
    12 Jul 2004
  4. Koolpc
    Koolpc Minimodder
    27 Jan 2005
    I am looking for one that is quiet with no fan! I will put a Samsung sata HD in it. Anyother ideas?
  5. riggs
    riggs ^_^
    22 Jul 2002
    When I sold my desktop and switched to a lappy, I kept the 400GB WD and stuck it in an enclosure. Works well enough, but the caddy is just a cheap chinese job - the fan in it started whining after a few months...
    TBH, I'd just go with a prebuilt solution. The main computer stores seem to always have some kind of offer on external drives.
  6. elmat
    elmat What's a Dremel?
    19 Aug 2007
  7. atanum141
    22 Jul 2004
  8. dragontail
    9 Jun 2005
    Thanks guys for the help. Will take all that into account :thumb:
  9. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    Will you be running it 24/7 or just turn it on when you need it? (The free agent pro's are definitely the way to go, or the WD versions of) I was just curious.
  10. dragontail
    9 Jun 2005
    Well, I was hoping for an external HDD which acted like an internal one. So it would spin up when needed (when reading/writing), and spin down when it isn't. This is cos the external drive is for data, but since I'm off to uni next month, I'm get to bring a lappy with the external HDD and keep my data with me :D
