Notebooks aspire one problems
Discussion in 'Hardware' started by notatoad, 24 Oct 2008.
  1. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    i dropped my aspire one yesterday, it fell about 3 inches onto a wooden table and landed on its corner while in standby mode. now it starts up fine but then turns off with no warning after 1-2 minutes. the battery is fully charged, and it does this whether it is plugged in or not, and the battery is fully charged. this usually means that it turns off within seconds of getting to a windows desktop, but it did a checkdisk once and turned off in the middle of that too, so i know it's not something in windows.
    the only cause i can think of is that the heatsink got disturbed when i dropped it, but is 1m enough time for an atom processor to overheat? can anybody think of any other reasons that it might be doing this?
    also, if i pull it apart to see if i can fix it, do i lose my warranty?
  2. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    If you still have the warranty, why not RMA it?
  3. ComputerKing
    8 Sep 2006
    I added a ram to mine and it didn't kill the warranty. I don't know about your store.....
    but that sounds like overheat or an wires not hooked good.
  4. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Can you claim it on your home/contents insurance? Many have accidental damage included.
  5. notatoad
    25 Jun 2004
    pull it apart to fix it myself = 1hr
    send it to wherever acer does their warranty = ? weeks
  6. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    no just a 3 days, last time i used there warranty on my laptop.
    Screen developed coloured vertical lines, loose connections to the LCD panel, could be fixed if i used a bulldog clip. I could have fixed it, but if i fubar'd it then i would have been screwed. one phone call, and a guy turns up the next day to collect, comes back two days later, they even cleaned the laptop! I know its mine as i marked it in certain hidden places with tip-ex.
  7. notatoad
    25 Jun 2004
    okay, it's getting wierder. i ignored the computer for a couple weeks, just left it sitting on my bookshelf. started it up today, and everything is working fine. i'm running orthos and coretemp right now, and the temp is hovering around 75ºC. if it was my desktop i'd be worried, but is this normal for a laptop? i know the netbooks are all are supposed to run fairly hot.
  8. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    My EeePC 701 averagess around 55-59C at full CPU usage.
    Maybe the fall disrupted the thermal grease between CPU & heatsink?
  9. notatoad
    25 Jun 2004
    so i finally got around to re-seating the heatsink with AS5. huge difference, haven't seen a temp over 55ºC so far :D
